Thread: PH test
    Aug 2016
    Chapmansboro, Tn
    36
    Red face PH test
    Hi all,
    if aerareing a pool raises ph level, should I shut off my
    pump an let water settle before performing that test?
    see what y'all have done to me?(lol)
    Thanks Bill
    New (Aug4th) AG, 8400gal, Ecokleer sand filter (45gpm max)
    1 1/2 hp Century ecokleer pump, Taylor K2006 kit
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,312
    Re: PH test
    No.
    I just invert the test block gently, and don't shake it, for the very same reason. So you're not alone.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,995
    Re: PH test
    No. Test you PH at normal intervals like you normally would/should. If your PH is rising due to airation as you mentioned, lowering your TA may help regulate your PH.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Re: PH test
    No.
    See...........I learned something else today!!
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
