Results 1 to 8 of 8
Thread: Raising Ph
    Jun 2007
    SE Louisiana
    18
    Raising Ph
    I added CYA Saturday and my ph dropped to 6.8. Should I wait to raise my ph? Also, the cya made my pool a little cloudy, but my pump isn't working properly either. Is this normal? TIA
    5K gal QS AG soft blue pool, 1500 gph pump
    It is common for CYA to lower the PH. You should raise it back up soon. It isn't good for the pool equipment/liner for the PH to be below 7.0.
    It is not common for CYA to make the pool cloudy.
    Jun 2007
    SE Louisiana
    18
    if i can't find the soda wash, can I use baking soda and borax together to lower ph and alk?
    Jun 2007
    SE Louisiana
    18
    I meant to raise ph and alk
    Jun 2007
    Atlanta, GA
    71
    Don't worry about the alkalinity too much, yet. The two best ways I can think of to raise your PH is to:
    1. aerate: run waterfalls or some kind of water that drops into the water to create bubbles. This will aerate your pool, raise your PH over time (check every 12 hours), and not really change anything else.
    2. Add 20 mule team borax. This will definately raise your PH, add a little borax (good for preventing algae), and increase your TA by just a little bit.
    If you post specific test values from a reliable test kit, like Taylor K 2006, you can get some additional help.
    Pool: 15,000 gallon 32'x18', 3'-6' deep in-ground gunite pool, Sta-Rite 3 125 GPM 2-filter cartrige, 1.5 HP Sta-Rite pump, solar heater, Goldline SWG, Jandy controls, opaque automatic CoverStar solar pool cover, 3 waterfalls (not from spa).
    Spa: 485 gallon in-ground square acrylic over fiberglass suspended over gunite Sunset brand spa, isolated system, natural gas heater, 2-speed (4hp/11hp) main pump, 3hp booster pump, chlorine sanitized.
    To my pool store owner, nothing is more important than my pool and my money.
    Richard's PoolEquations Spreadsheet
    Jun 2007
    SE Louisiana
    18
    I have the ones from the pool store...
    Saturation Index -0.96
    pH 6.9
    cya 16
    Adjusted total alk 83
    Calcium Hardness 65
    Everything else was ok..
    What is the saturation index? In the analysis section mine said corrosive...
    The saturation index tells you how the water will react with plaster surfaces (plaster is also present with pebble, tile, stone, etc). If you have a plaster surface you have a problem. If you have a vinyl liner it doesn't mater if it is negative but can still be a problem if it is too high positive.
    Jun 2007
    SE Louisiana
    18
    and...
    my calcium hardess was 93, not 65
