Thread: Hi, new here and need help with water balance
    Apr 2017
    Hackettstown
    1
    Hi, just opened the pool this past Sunday. My wife took a water sample to the pool store. We have a 33,000 gallon Lazy L, DE Filter, Automatic Chlorinator. The numbers produced by pool store, PH 6.2 TA 34, Free Clor 0.00 Total Clor 0.00. Total Hard 131 CYA 122 Optimizer Plus?
    42, Recommended 48.5 lbs Balance Pak 100, 3lbs Balance Pak 200, 5 lbs Burn out 35, 26 ozs Algae All 60, 1.5 quarts Pool Opening Complete I will be ordering a TFT kit. Are there other products to use that would be cheaper to get these numbers to the right levels. I am putting my house on the market and need to have the pool looking good for the Open House in 2 weeks. Any advice would be greatly appreciated.
    AimeeH's Avatar
    Apr 2012
    Columbia SC
    1,994
    Re: Hi, new here and need help with water balance
    Welcome to TFP
    Oh wow.....I haven't read up on what all those chemicals even are. Click the link at the top of the page and browse pool school. The number one thing you need to get correct advice here is a proper test kit. We absolutely don't trust pool store testing in general. So depending on your test results, these are the items we typically use to maintain a pool:
    Bleach (liquid chlorine)
    Muratic acid - to reduce PH and TA if necessary (found in the hardware store paint section)
    Baking soda to raise TA if necessary
    Soda ash to raise PH if necessary
    CYA -cyuranic acid if necessary (sold in the pool section of big box stores)
    If your goal is to keep it clear mainly for showing, your "most likeley" course of action is just to get it clear with chlorine and maintain with chorine (bleach) but all those test numbers matter as far as advice on chemical additions.
    18*36*23 true "L" vinyl IG 29,000 gallons. SWG. TF-100 test kit.
    http://tftestkits.net/splash-page.html
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    20,296
    Most of those chemicals are just repackaged overpriced stuff you can pick up at Walmart or the grocery store.
    If it's not too late, add nothing but maybe half a jug of plain laundry bleach every day and spend your money on a proper test kit. Armed with reliable test results and some reading in pool school, you'll get the chemistry in line and have enough money left over to buy the beer for the opening day festivities.
    If it is too late, get the test kit anyway. Read the labels from the stuff you added. If any of those contain monopersulfate, they'll mess with your CC test results.
