Thread: Preferred water bonding method
    May 2014
    St Louis, MO
    39
    As the title states what is your preferred method of water bonding for an above ground pool?
    Thanks
    24'x52" AGP 13,200 Gal Hayward Sand Filter w/ Matrix 2 speed pump Liquidator Taylor K-2006 Test Kit
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Preferred water bonding method
    Two most popular methods are the waterbug fitting which installs in the skimmer and the permacast fitting which goes into the plumbing with 1" npt threads.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
