Thread: 3rd test. / K-2006
    Apr 2017
    Hesperia, CA
    18
    3rd test. / K-2006
    Just when I think I'm getting the hang of it..... : /
    FC = 2.0
    PH= 8.0 ( One drop of acid takes me to 7.6 )
    TA = 90
    CH = 170 ( Added 5LB last night, will add another 5lb tonight)
    CYA = 60
    CC= 0
    I think I'm getting closer, but I went over on my CYA.
    Any advice please ???
    Thank you....
    Mike.
    18 X 38, 18K gal, IGP W/ Infinity Spa. EasyTouch 8 ch
    Pentair 1.5HP VS pump, Pentair Cartridge Filter
    Pentair 250K HD heater, Del Ozone Corona Discharge
    - Generator ( Eclipse 10 ).
    Pebble Tec Finish. Dolphin Triton Plus vacuum.
    triptyx's Avatar
    Apr 2016
    1,476
    Re: 3rd test. / K-2006
    60 CYA isn't terrible, especially if you're in a fairly sunny spot.
    Pool School - Chlorine / CYA Chart
    With a CYA of 60, we need to get your chlorine up over the minimum of 5 ASAP, 2 is too low. Your target should be 9 when you're doing your daily chlorine dose.
    After letting that chlorine mix in for a half hour or so, you'll need to add enough muriatic acid to get the pH down to either 7.8 or 7.6. You can play with those two numbers over the next few weeks and see if the pool needs to go to 7.6 or if it can hold 7.8 for a long enough time that you don't feel like you're adding acid too frequently (too frequently being when you say to yourself "darn, I have to add acid again!?!?!).
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
