Thread: Anchor Cups for Use With Pavers
    Jul 2009
    Long Island, NY
    267
    A couple of years ago I found an railing anchor cup that was specially designed for use with paving stone patios. It has the normal depth that must be embedded in concrete but had an extension at the top which would end up being flush with the top of the pavers. these solved the problem of the sand bed that the pavers are set in from filling the cup.
    Now that I want to buy them, I can no longer find them. Has anyone see these or can give me the names of manufacturers who make anchor cups so I can do further research?
    Free-form concrete walls with vinyl liner, 18,000 gallon capacity, Jandy 1.5HP e-Pump, Jandy DEV48 DE filter (using cellulose media), Jandy AE2500 heat pump, Jandy Aqualink Power Center with 14-blade cell kit and Jandy PDA-P8 wireless control system.
    Re: Anchor Cups for Use With Pavers
    I would suggest that you contact INTER-FAB and S.R SMITH. They should have a solution.
    Support the site
    Jul 2009
    Long Island, NY
    267
    I ended up finding the anchor cups last night. The manufacturer is Perma-Cast and here is a link to the brochure for the product. They call it The Big Boy Super Socket.
    Jan 2017
    Orlando/FL
    124
    How is that supposed to be installed? Since it is not round you can't core drill a hole and insert. Does it get installed under the pavers (then what)?
    I have an umbrella mount for my paver deck that is just round sleeve. You core drill hole in paver/deck and insert the sleeve (for paver deck you would need/want to pack some cement or thinset around sleeve then install). Umbrella pole then goes into sleeve. It has a cover too. https://www.amazon.com/Waterway-Plastics-540-6700-Volleyball-Holder/dp/B00HEAUMS4/ref=pd_sbs_86_2?_encoding=UTF8&pd_rd_i=B00HEAUMS4&pd_rd_r=H6 F2CTR3KSSGNXFRVBW0&pd_rd_w=7J5YN&pd_rd_wg=EmAi8&psc=1&refRID =H6F2CTR3KSSGNXFRVBW0
    The plastic sleeve I have is fine for umbrella (of volleyball net) but won't do much if you need to "anchor" or pull against it.
    20K gal In-ground pool with raised Spa overflowing into pool; two Jandy Sheer Descent waterfalls; Pentair IntelliTouch i7+3, IntelliChlor, IntelliPH, 3 SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, RayPak 406A LP spa heater, Polaris 360 PS Cleaner. Patio and deck lighting by Volt; Volt 600W landscaping transformer; Webber grilling station
    Jul 2009
    Long Island, NY
    267
    I think you core-drill a hole that fits the non-round anchor and then use hydraulic cement to set it in place. The manufacturer has some other literature on their website which may help. I'm looking to buy a couple this spring to replace my plastic anchors which: 1. Flex and 2. fill with sand since they are set in concrete below the paving stones. The length of these anchors will allow concrete encasement below the paving stones and extend flush to the top of the pavers preventing them from filling with sand. If I get them, I'll report back with some pictures.
