Results 1 to 14 of 14
Thread: Inheriting High CYA Pool
    Apr 2017
    Phoenix
    500
    Greetings everyone. A month ago, I moved into my first home and it has a pool. Unfortunately, the pool I inherited had a high CYA. My testing strips say it’s over 180. (Before I get negative comments on using strips, I have a Taylor K-2006C on the way). This is because the previous owners had a pool guy that was too incompetent to read the forum and he was so bad that he placed the pucks directly in the basket of the top skimmer.
    I know that the recommended way to lower the CYA is to drain the pool or at the very least drain a portion of the pool and refill. However, with temps already in the high 90s in AZ and the pool staying clear despite the high readings, I am struggling to convince the Mrs. that I need to drain the pool.
    I think I may be able to convince her that I will drain (via backflush) and fill with a hose at the same time so the water level doesn’t go down. I have read some people say that this method is not effective because when you drain you will be losing some of the “good water” that you put in with the hose. However, doesn’t the CYA from the old water immediately mix in with the new water and spread it out evenly? So even if you pump out the water that was just put in, it will take out the same amount of CYA?
    Lastly, if I am unable to drain the pool now, should I just keep using the pucks and trichlor until I can drain the pool? Based upon my lurking, it would take an unreasonable amount of bleach to get the chlorine levels to where I need them.
    Thanks for your time,
    16,000 gallon in-ground pebble tec pool. Hayward SP3400VSP Eco-Star Pump, Pentair Triton 2 TR-100 sand filter, A&A 5-port in-floor pool cleaner, Pentair Intellibrite 5g color changing pool light, Polaris 965iQ Robotic Pool Cleaner, OG Pool Math Subscriber and most importantly a Taylor K-2006C test kit.
    Test Kits Compared
    | SLAM | Chlorine / CYA Chart |
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,327
    Re: Inheriting High CYA Pool
    S,
    Welcome to TFP... A Great resource for all those husbands hesitant to drain their pools...
    I suggest you wait until you new test arrives. Since "guess" strips are almost useless, your actual CYA level could be much less, or much more than you realize.
    Once you know the real number it will make the decision easier..
    Thanks for posting,
    Jul 2015
    Central Valley CA
    1,166
    Welcome signature on your first post awesome
    Is your pool truly 18,000 square feet? that is more of a small lake
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Apr 2017
    Phoenix
    500
    Quote Originally Posted by atttech-2 View Post
    Haha, about the size of the Great Salt Lake. So I guess I don't need to chlorinate it.
    Test Kits Compared
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,908
    If your pool is clear and once you get your test kit you can determine via an Overnight Chlorine Loss Test that there is nothing growing in the water then there is no dire emergency.
    I inherited my pool with CYA in the range of 250. I maintained the proper level of FC for that high a CYA and moved forward.
    Things that I did:
    - Backflushed my sand filter for almost any reason and ran it longer than usually is necessary.
    - Vacuumed to water if I saw stuff on the bottom of the pool.
    - Did a few small/partial drain & refills
    - Rigged up a system to capture rain water form my downspout and directed it into the pool
    Over two years I slowly reduced my CYA to the point that this year I had to add it as the water began to warm.
    The key is the proper amount of FC all the time. Let it slip and allow algae to get a foothold and you will need to SLAM.
    If your CYA is really 180 then your FC must be kept at 14 as a minimum and I would recommend 16 as your target. The problem you will have is the pH test reads incorrectly high at FC above 10. To test pH you will have to allow the FC to drop, test and raise the FC immediately. It can be down but it takes watching it like a hawk.
    Support the site
    Apr 2017
    Phoenix
    500
    Quote Originally Posted by tim5055 View Post
    Things that I did:
    This is exactly what I needed to hear. I started to feel like it was helpless unless I drained immediately. It's good to hear that I can still start using liquid chlorine now, and over time I can bring the CYA down overtime by back-flushing and dilution.
    Test Kits Compared
    May 2014
    Franklin, NC
    9,908
    Quote Originally Posted by spinPHD View Post
    You can, but you have to be diligent. Either a SWCG or liquid chlorine only. No tabs for vacation, no shock because it's easy.
    This includes vacations. Start thinking now of who can come over and pour chlorine in your pool while you are gone.
    Support the site
    mas985's Avatar
    Pleasanton, CA
    11,988
    I have had good success with this method but I supply water to a skimmer (that is shut off) in the shallow end while drawing from the MD only in the deep end. This helps to keep the water separated. I was able to replace about 90% of the water without mixing.
    Mark
    triptyx's Avatar
    Apr 2016
    1,476
    That said, we're suppose to have a "cold front" late next week. If the weather actually does get into the 80's, and you're willing to use a hose to keep the exposed plaster moist, you could look at doing a partial drain/fill then. I did this in April last year after inheriting a pool that had similar CYA issues. I used a rented submersible pump from a local hardware store to get the water out fast.
    mas985's technique also worked very well for him, so that's definitely another great option.
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    Apr 2017
    Phoenix
    500
    Quote Originally Posted by triptyx View Post
    My pool is pebble tec. I didn't think you needed to worry about keeping it moist when you drain.
    Test Kits Compared
    triptyx's Avatar
    Apr 2016
    1,476
    It's still plaster based (all those pebbles are embedded in and held together with plaster), so you do still need to be concerned about keeping it moist and not letting it "bake" in the sun, as well as ensuring you're keeping the correct chemical balance for plaster pools.
    Jul 2016
    Philly Suburbs
    27
    You could do it over several stages. For example if you drained 10% of your water and then filled it right back up you'd be at ~160, do it again you'd be at ~145, ~130, ~115. 10% of the water isn't really that much...you could still swim in it.
    22,500 gallon in ground pool with vinyl liner. DE filter. Taylor K-2006.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    Quote Originally Posted by mas985 View Post
    I did this as well recently. Had a small bout of metals in the water when I added the first chlorine of this year.
    For my last house/pool the previous owner also had pucks in the skimmer.
    after I got the TF100 test kit, i had to do a dilluted CYA test and it was reading 350+
    The ph was also not good at 6.8
    I did 2 partial drains / refills down to the pool light and started draining it at 6pm once
    the sun was no longer showing on the plaster. It was drained to the light by 9pm
    and filled up to the water line by 7am the following morning.
    This took the cya down from 350+ to a much more manageable 70.
    The water was really expensive in that area and I ended up selling the place so that's how I left it.
    Dolphin E10 Cleaning Robot.
    Jun 2016
    Martinez, CA
    241
    Some people have used a tarp (attached across,the top and vertically with weights on the bottom) in the pool to keep new water additions from mixing with the old thereby improving the drain and fill process.
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
