Thread: House with Vinyl slightly Above Ground Pool that needs some help
    Apr 2017
    Rialto California
    2
    We live in a house with a vinyl pool slightly above ground. (for reference, see Secards pool).
    First there was a root that was left edging the liner though it was requested to be moved (it was not) and is pushing on liner - this issue will not be replaced until new liner will be installed. Please beware of those who do the installation of your pool and what they are doing during construction.
    Our current issue is that they constructed of wood - some treated and some well plywood worries us. So we are trying to figure a way to install backer-board to consider tiling or installing brick. However since we cannot drill into plywood next to pool vinyl, we need suggestions on how to accomplish this so we can block, brick, or tile to preserve pool longer. We are DIYers. Open to any suggestions. I will try to attach a photo.
    Pool Minded
    Rialto, CA
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: House with Vinyl slightly Above Ground Pool that needs some help
    Just to recap, are you looking to veneer the exposed wood to beautify or are you looking to add a structural component to exposed wood sections?
    As for the root, I would consider cutting wherever you can expose it between the pool and the tree. Preferably closest to the pool surround.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Apr 2017
    Rialto California
    2
    Pool is 12' x 24' Vinyl inground with 2 feet out of ground. Pump is cartridge and treated with chlorine not salt.
    Thank you on root. That will be some digging. : (
    Yes we want to beautify and add structural. Probably using block to cover all the wood. I tried to upload a pic but was unable.
    Last edited by pool minded; 04-20-2017 at 08:17 PM. Reason: Tried to add picture but unable to load
    Pool Minded
    Rialto, CA
