Results 1 to 7 of 7
Thread: Trichlor tab stained pool
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Went on vacation for 3-4 days last week and used some tabs (first time in a long time). When I came back, I was cleaning out the skimmers and doing yard work etc. There was a leftover piece of tab about the size of a then 50 cent piece that I accidentally left on the side of the pool and me/my wife/the dogs knocked it into the pool. It was dark when we finished up so I didn't see it and this morning I noticed it in there. I fished it and it broke into a million pieces so I ended up just vacuuming it out.
    However, it looks like it left some stains on my plaster from being left there over night. Is this permanent?
    Memphis, TN.
    Pool IG, 20K gallon, Gunite. Triton Sand filter, Pentair Pump, Polaris 280, Doheny Discovery Dolphin, Chlorinating Liquid, Rock Water Feature, New Plaster 2015
    Spa 450 gal, Tropic Seas Waikiki 864L, Bromine
    Taylor K-2006
    Donldson's Avatar
    NW Ohio
    3,220
    Re: Trichlor tab stained pool
    It depends on whether you are dealing with a stain or bleaching. Are the spots faded or white? If so then it is bleached, the pigment is gone, and yes it is permanent.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    It's not white. It darkened almost like an organic stain.
    Memphis, TN.
    Taylor K-2006
    Mod Squad JohnT's Avatar
    SW Indiana
    9,334
    Quote Originally Posted by Bigdog43 View Post
    What does the rest of the surface look like? If high chlorine darkens the pool surface, my first thought would be copper. Is this a "3-way" tablet? Do you know if you have copper in the water?
    Bigdog43's Avatar
    Jul 2016
    Memphis, TN
    172
    Quote Originally Posted by JohnT View Post
    Yes. The product is from Poollife and called something like MPT 3 and it contains copper sulfate.
    Previous owners also had a mineral sanitizer, (cartridge since removed), but it was putting copper and silver in the pool. Never did anything to get rid of it so I'm sure some is still in there.
    Might it be a metals stain I can get rid of with vitamin C?
    Memphis, TN.
    Taylor K-2006
    SW Indiana
    9,334
    The Vitamin C method only works with iron.
    You might be able to scrub the stain off with a sock containing dry acid or pH Down.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
