Results 1 to 9 of 9
Thread: Pool prices in metro Atlanta
    Apr 2017
    Atlanta ga
    2
    I've been a lurker for a few weeks and would love to get an idea on what the going rate is for pools in our area. We are looking at a gunite 16x34 with spa. So far we have received a quote of $61K (includes pebbletech which we don't really want) and that didn't include landscaping or anything. Beginning to think we will never be able to afford one. I had our top budget maxed at $50K. Any opinions or suggestions? Or is my budget way off?
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    Re: Pool prices in metro Atlanta
    You could look at fiberglass, as there are units in that size range that may be closer to your budget. We went with a 38x16 x 3.5-8' fiberglass, outside ATL that started without all the options under your budget. There are some with built in spas. We love our pool - did not get one with spa, but instead had built in loungers and table.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Get at least 3 quotes to get a good feel for the market and how comfortable you are with each contractor. Should be able to get that many quotes in your area. Think hard about what you're going to use to pool for now and in several years to determine what shapes/depths/size you really will enjoy.
    Isolated Spa - 345 Gallons
    Apr 2017
    Atlanta ga
    2
    Stupid question but are all of the fiberglass pools plain white?
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    Quote Originally Posted by Fsufam123 View Post
    Many color options. We chose a caribbean blue color
    jimbowrench's Avatar
    Jun 2015
    Littleton, CO
    13
    Fiberglass pools come in numerous colors, and more sizes and shapes than you could possibly imagine. I have had both fiberglass and gunite, and I am going with fiberglass again. Currently installing a San Juan Atlantic Deep Pool and San Juan Royale Spa. My base price for the pool installed was under your budget number and similar in dimension as to what you want. I would think that in a market such as Atlanta you could find more aggressive pricing than what I could get here in Colorado.
    You have definitely come to the right spot. Learn and utilize the techniques here on TFP, and your pool ownership will be easy and enjoyable. Good luck with the journey!
    San Juan Atlantic Deep Inground Fiberglass, 11,300 G; Pentair Clean & Clear Plus 400; Mastertemp HD 250K BTU NG; Intelliflo VST Pump; Intellichlor IC 40 SWG; The Pool Cleaner
    San Juan Royale Fiberglass, Spa 700 G; Pentair Clean & Clear Plus 150; Mastertemp HD 250K BTU NG; Whisperflo 2 HP/2-Speed Pump; Intellichlor IC 15 SWG
    Intellitouch Controls
    bmoreswim's Avatar
    Jul 2012
    Central MD
    4,153
    Sounds obvious but your quotes are the market price. Almost all people set an original budget less than market then decide if to proceed or modify their plans.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    571
    Here is a local fiberglass pool manufacturer. We used a local installer that installs these pools. Many options to choose from - models, colors, borders, spas, ....
    We chose an installer to do it all. But the mfgr has a "assisted install" program where they deliver and install the pool into your hole - so you are acting as the pool builder. I was too paranoid to do this and was very happy with our builder. You should be able to get a pool in your price range, but size, options (leds, diving board, ...) , additional cement decking, can bump it up. That is why we left built in spa out, figure we could add a really nice standalone one in the future if we want.
    BTW - we installed the Caribbean model.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    FSU's, another option in addition to fiberglass that may help you get the enjoyment of a pool without going over your budget would be a vinyl liner pool, which is usually less expensive to install, and nowadays, can accommodate a variety of shapes/designs. Between shaped composite walls and cantilever coping, its possible to achieve some of the features that attract people to gunite.
    With in ground vinyl, you do have the eventual cost of liner replacement over time...but with gunite you eventually have
    re plastering cost.
    My pool came with the house I bought. Given the intrinsic enjoyment I get from it, if I were in a new-build situation I would not have any compelling reason to spend more on gunite if I wasn't comfortable with the budget. And I'd certainly go inground liner before I'd go without
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
