Thread: How to know exactly how many gallons my pool has
    Apr 2015
    Nashville
    41
    I have a 18 x 32 pool.. shallow part (nearly 1/ of the pool) slopes from 3ft to 6 ft and then drops to 8 - 8.5 ft. Rectangular pool. With pool calculator it shows as 30,000+ gallons but I think it is not that much. As I need to buy 40lbs bags of salt. How many bags of salt do I need or exactly how many gallons do I have?
    16 x 32 (3, 5, 11)
    23-24,000 volume
    Liner Pool
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,941
    Re: How to know exactly how many gallons my pool has
    Play with your PH levels. If you PH is at 7.5 right now go to pool math and see how much muratic acid you would need to add to push the PH down to 7.3. Add it, let the pump run for about 30 mins. then retest. If it went lower than the target add 500 gallons to your pool size. If it did not got as low as the target then take away 500 gals. Play with it this way over a couple of days and you can dial in the gallons within about 500 gals.
    Kim
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    pH can be a little tricky for calculating volume, as it's influenced by TA and less stable over several days, but doable. You could use your first salt additions to measure your pool volume. You'd have to have a salt test; ideally a drop based for a bit better accuracy. Measure your initial salt level. Figure out the ratio of your expected concentration versus your actual measured after adding and that gives you your actual volume. Calcium hardness and CYA are other good levels to use as well.
    Isolated Spa - 345 Gallons
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Quote Originally Posted by phillipjko View Post
    When I do the calc I get around 24800. So I think the size you have listed in your sig is pretty close.
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    235
    I concur with pabeader- you have to be around 22-24 gallons from your geometry provided.
