Thread: When to replace sand filter
    Jun 2016
    Webster Groves, MO
    14
    I have a Pentair TA-100D sand filter that I am guessing is 15 years old based on the age of some of the other equipment I've replaced. The multiport valve is shot so at a minimum I will need to replace that.
    I'm wondering if it's worth replacing the valve (looks to be around $200) vs. replacing the entire filter (looks to be around $650 delivered). It looks like the fiberglass is "wearing" on the inside and out, but I'm not sure if that is just cosmetic. Does the filter body itself have a lifespan that I am nearing the end of, or with new valves do they last forever?
    Thanks
    Brian
    35k gal IG plaster (25 x 45ft), 3HP Intelliflo FX, Pentair Quad DE 100, Intellichlor IC60 SWG, Polaris 280 w/ PB4 booster pump, Raypak P-R406A
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: When to replace sand filter
    They last a long, long time. Most of the time way more than 15 years, and indefinitely depending on how weathered it gets. Or if it gets damaged. If isn't cracked and leaking, and you can get parts for it, then why change it is my thought. Sometimes the valves just need new gasket kits put in but if its shot, slap a new one on and go.
    I seriously doubt it's near the end of it's life by a long shot. Here's one recently posted, and still in service, made before it was even a Pentair branded filter.
    Essential Links:
    Jun 2016
    Webster Groves, MO
    14
    Great to know, thank you.
    Now I just need to decide if I want to keep it. If it was near end-of-life I was thinking of the Pentair Quad-DE... and now that I've been thinking I'd be getting that, it's hard to unthink it!
    Jan 2017
    Monterrey, NL, Mexico
    491
    You can keep it and and some DE to sand filter. Search in pool school.
    Felipe
    7,500 gal Rectangular, Easytouch 8, Air+water temp sensors, Screenlogic2, IC40, intellibright5g color12v, Intelli pH, SD 70 filter w/Zeolit, Magicstream Laminars, waterfall. Raised Monolithic concrete lined with glass beads.
    In Sunny Monterrey,Mx!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Well, if you just want a new filter because you want DE, nothing wrong with that either. It's up to you entirely.
    Essential Links:
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    Don't fix it if it ain't broke!
