Results 1 to 7 of 7
Thread: Think i found the "leak"...duh moment of the year!
    ta2dwonderwoman's Avatar
    Jul 2016
    fall river ks
    502
    So, i found that on two different days recently that i had lost 2-4 inches of water, seemingly overnight.... it has been kind of hard to pin it down because of all the backwashing I've been doing in the process of getting the pool clean not to mention the partial drain I had to do to replace a part on my return jet. I filled the pool back up to full 2 days ago and when I got home tonight and noticed that my water was way low again... started talking too hubby about it and he mentioned that the ground was pretty wet out by our faucet, which he had mentioned previously but it was shortly after rain so we didn't think a whole lot about it. When he mentioned it I went right outside and checked and sure enough it wasn't just slightly wet there was actually standing water on the ground around our faucet. At that point we realized that what was happening was that when we turn the water off after filling up the pool and did not remove the hose it created a back suction and started siphoning water back out of the pool... at least that's my theory at the moment. We filled the pool back up tonight and removed the hose after we were done and will now keep an eye on it for a few days to see if we lose any water. Pretty sure our leak is not a thing!!! I was really struggling to understand how we could lose that much water that fast and the ground around the pool wasn't wet at all, so this Theory explains a lot of things I've been puzzling about...
    Derp.
    Windy ☆ 22ft round, 11,400 gal, intex ag vinyl, SF70110-1 Intex sand filter/2800 gph pump, CS8110 intex swg, city water, solar heater, TF100 test kit/speed stirrer, over the wall intex skimmer~fall river ks~SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math
    philc's Avatar
    Jul 2015
    Grand Island Nebraska
    190
    Re: Think i found the "leak"...duh moment of the year!
    Congrats keep us posted if this fixes the leak
    Intex 22' X 52" Ultra Frame AGP ( 12K gallons) , Intex 633T 2500 GPH (41 GPM) running Doughboy Silica II sand filter (16"dia. 1.4 ' S.A.) ( And doing it quite well, I might add!) Hayward through the wall skimmer, TF100 with Speed Stir. Hard plumbed, Intex fountain ...........
    Jul 2016
    fall river ks
    502
    I feel so dumb if this is what the issue is. .. but oh so happy!
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    No reason to feel dumb. The important thing to take away from this is that you and your SO communicate and work out stuff. That is a lesson we can all learn!
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Jul 2016
    fall river ks
    502
    this guy is my teammate and the to my wonderwoman! I do most of the pool stuff, but he is my muscle and helps when a lot of walking back and forth is needed (getting stuff and turning water off and on since it is at the front of the house)... with my copd, I am limited is so many ways as t what I can do, but the physical requirements needed to keep up a pool are exercise for me without actually exercising! it works out well and keeps me moving, which helps prolong my lifespan and quality of life!
    just glad he spoke up...when it happened for the 2nd time and water around the spout was mentioned both times, a light bulb finally went off! SIPHONING! started telling a co-worker and he asked if we had a "horsehead" type handle on our faucet...I said "why yes we do" - he told me that he filled up a horse trough a few times and it kept sucking the water back out because they are built with some sort of pressure thing inside and if you leave them in water, and turn them off, they will SIPHON the water right back out! who knew?????
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    The little round disk behind the valve handle for your hose bib is actually a backflow preventer. It prevents your hose from siphoning anything back into potable water system. To do this if your hose does start to siphon that little round disk closes the pipe to the house and opens up a port that dumps what ever the hose is siphoning to the ground. Backflow preventers became mandatory on hose bibs in the late 80's or 90's I think.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jul 2016
    fall river ks
    502
    which completely explains the standing water on the ground all around my faucet!
