Results 1 to 14 of 14
Thread: Ta=250???
    Liberty, Tx.
    28
    Ta=250???
    I started my pool up about a month ago and have had great test results using a 4 year old TF-100 kit.
    FC=8
    PH=7.2
    TA=110
    CYA=60
    Started running out of test chemicals so ordered a new refill kit and received it last week. This past week we have gotten quite a bit of rain and had to drain about 4" off this past week. Today I used the new test kit and the TA is now showing 250. Does the TA test chemicals expire over time? Dont know how the TA got so high over the past week.
    FC=8
    PH=7.2
    TA=250
    CYA=45
    Intex 22' x 52"
    Intex 2500 gph
    TFPC Method (BBB)
    Re: Ta=250???
    Highly unlikely that your TA is 250. Can you describe your test procedure?
    Support the site
    Liberty, Tx.
    28
    Re: Ta=250???
    Quote Originally Posted by JamesW View Post
    25ml water sample, 2 drops of R0007, 5 drops of R0008, swirl to mix well. Swirl while adding 1 drop at a time of R0009. Same as I was doing before with old kit. I just went out with old kit and TA=250 also.
    Intex 22' x 52"
    Intex 2500 gph
    TFPC Method (BBB)
    Re: Ta=250???
    What have you added since opening?
    Support the site
    Liberty, Tx.
    28
    Re: Ta=250???
    Not really an opening but drain, power wash and fill. When filled added muriatic acid to get ph down to 7.2. Then added bleach to get FC to 8. Then 4lbs of stabilizer from walmart. Nothing else has been added (other then these). My TA was at 110 through several storms. Then today's rain and its showing 290 as of a few minutes ago. When I used my old kit today I was completely out of R0009 so I used the new reg. R0009 is the only thing different. Might be my imagination but the drops look smaller then my old R0009.
    Intex 22' x 52"
    Intex 2500 gph
    TFPC Method (BBB)
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    577
    Re: Ta=250???
    Quote Originally Posted by rkersh409 View Post
    Did you wipe the tip after every drop? I have to so just throwing that out there!!
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    Liberty, Tx.
    28
    Re: Ta=250???
    No I don't wipe LoL. Never heard that before. What is the reason for wipping? Will give it a try tomorrow
    Intex 22' x 52"
    Intex 2500 gph
    TFPC Method (BBB)
    Re: Ta=250???
    If static builds up or the tip is wet, the drops can be the wrong size.
    Try testing your tap water.
    Is it city water or well water?
    Support the site
    Liberty, Tx.
    28
    Re: Ta=250???
    City. What should tap water read?
    Intex 22' x 52"
    Intex 2500 gph
    TFPC Method (BBB)
    Re: Ta=250???
    Not sure what yours might be. Just wanted to compare.
    Might be a bad dropper tip.
    Support the site
    Liberty, Tx.
    28
    Re: Ta=250???
    So this morning I tested the water like I normally do TA=220. So I changed the tips from my old bottle, no change. Tested my tap water and TA=290. So I got another sample from my pool. 1 drop and wipe and finally got TA=110. Thats weird that I have never had to wipe the tip before.
    Thanks for the help.
    Intex 22' x 52"
    Intex 2500 gph
    TFPC Method (BBB)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Ta=250???
    That is unusual but not unheard of. Water I've dealt with is 180-200 TA not too far from me, but I didnt know it was that high in that part of Texas. Still, that is quite a disparity between the results even wiping the tip. I know this comes up, and it is occasionally a problem, I've just never experienced the static issue. If you can repeat that, then go with 110. The R0009 should last a very long time under good storage conditions just as an aside, but its always best to have fresh reagent. They simply don't warrant saving money on for the huge value they provide.
    Essential Links:
    Liberty, Tx.
    28
    Re: Ta=250???
    Patrick I tested my pool water again, doing the wipe method and TA=110. So I guess I have static bulding up on my tip. I also tested my tap water again wipping tip and TA=170. So pretty close to what you are seeing.
    Again everyone thanks for the help.
    Intex 22' x 52"
    Intex 2500 gph
    TFPC Method (BBB)
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Ta=250???
    Excellent, glad to hear you got it sorted, and thank you for letting us know.
    Essential Links:
