Thread: Significant PH rise after heavy rain?
    Mar 2017
    League City, TX
    28
    We just finished up with a couple of days of heavy rain which brought the pool level up around four inches. I started my SWG on a shock cycle yesterday . I did a full set of TF-100 tests today (minus CYA which will be a whole other thread on that chemistry question) and got mostly what I expected given dilution. The surprise was PH which went from 7.5 to somewhere above 8.2 in that timeframe. I would have expected it to drop with rain.
    Any insight?
    Chris
    17k IG plaster, Pentair FNS DE, Aquarite 40k SWG, & Polaris 380 (AKA "Jacques") using city water
    Jun 2016
    Florida
    32
    Re: Significant PH rise after heavy rain?
    Two things:
    1. Aeration from a heavy rain can raise pH, though I doubt that significantly.
    2. Most likely culprit is the super chlorinate mode you turned on. pH rise from an active salt cell is significant, especially when the cell is producing chlorine 100% of the pump run time as is the case during "shock" mode.
    By the way, what was the alkalinity out of curiousity?
    Mar 2017
    League City, TX
    28
    Ah. Understood on the SWG. TA is 90, been slowly working it down from 140.
    Chris
    Dec 2016
    Arlington, Texas
    291
    [LifeHack]In order to extend the life of your cell, any time you need to raise FC quickly, just add bleach. A cell is best utilized to maintain an FC level.[\LifeHack]
    310 gallon Tiger River Sumatran Spa, covered, standalone, fiberglass, Bleach
    11,000 gallon in-ground plaster pool, Hayward SmartFilter 550 (cartridge), CompuPool(Hayward) T-15 SWG, Hayward Super II pump
    Taylor Test Kit K-2006C, K-1766, SampleSizer, SpeedStir, Polaris P825
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    It's Aeration from both Chris. Also two days time, and higher TA. It all adds up. A little more than I would guess, but there are always surprises. Could be a little testing variation in there too, but no worries either way. I agree that having some fresh bleach around is never a bad thing when you need a little boost.
    Essential Links:
    Mar 2017
    League City, TX
    28
    Will do, makes sense now. Thanks!
    Chris
