Results 1 to 7 of 7
Thread: well or city water
    Apr 2017
    Rochester, NY
    7
    well or city water
    Hi all, first time pool owner here. I have city water plumbed to the house, and I have well water plumbed to the exterior spigots. That being said, when bring the water level of the pool back up to the correct level in the spring, is it ok to use the well, or should i run a hose into the house somewhere to top off the pool? Obviously the well is cheaper (free! sort of.... minus the pump electricity and wear and tear) and the easier option since that is the exterior spigots. Will this give me headaches later on? Thanks for any insight
    18'x36' 24000 gallon Gemini IG vinyl liner, Pentair SD80 350lb Sand Filter, Pentair 1.5HP Superflo Pump, Pentair Mastertemp 250k BTU Natural Gas Heater, Pentair Easy Touch Automated Control System, Pentair Easy Touch Indoor Control Panel, Pentair Intellibrite Color LED Light, Taylor K-2006 Test Kit, well water
    triptyx's Avatar
    Apr 2016
    1,476
    Re: well or city water
    Have you determined if there are any metals (iron, copper, etc) in your well or city water?
    8,500gal plaster in-ground with attached spa, two floor drains, one skimmer. Chlorine, City Water.
    Pentair WhisperFlo 1hp Pump, MagnaTek Midcentury EPlus motor, Pentair CleanNClear 200SF Cartridge filter, Purex Triton MiniMax 250 Gas Heater, Pentair SunLite, AutoFill.
    Kreepy Krauly Cruiser, TF-100 with SpeedStir. :D
    JoyfulNoise's Avatar
    May 2015
    14,096
    You should have both sources of water tested for iron and other trace metals. You should also test both sources to see pH, TA and CH levels. If metals are not present in either, then I would choose the water with the lowest combined TA/CH levels (that is, CH+TA and pick whichever is smallest). If metals are present in your well water (which in upstate NY is highly likely), then I would not add water form the well. Iron is typically the biggest problem and, if you add enough iron, your water will turn tea brown from oxidation by chlorine. It can be filtered out over time, but it's a pain to do so.
    Matt
    Apr 2017
    Rochester, NY
    7
    Doing a little looking, people seem to think testing for metals is better left to the pool stores instead of purchasing a test for those metals yourself as they can be expensive. Has that been the consensus on here as well? Thanks again
    May 2015
    14,096
    Quote Originally Posted by BillyG View Post
    The downside risk to that is that pool stores often do such a lousy job at testing that you can't often be confident in their results.
    Being on a well, does your municipality offer any kind of free or paid testing service? Some do that to ensure that people within a water district are getting safe water...you could also pay for an independent lab test such as a place like National Testing Laboratories or another testing lab close to you. At least with those paid labs, you're more likely to get high quality results.
    Matt
    Jun 2016
    Jamestown, SC
    86
    Our county tested our water, though it cost $75 and took 2 months. I think I've seen iron test kits for about $75 too. Ours showed 2.1, and normal is something like .2ppm.
    We filled our pool from the well and had the pea soup/tea colored water from the oxidized iron (we were at slam level because hubby thought it was algae). Once we understood the problem, we filtered out the iron over 2 days (for our 5k gallons) and the water has been great ever since. We spent less than $20 and made a giant filter, piece of cake. Luckily we don't have to top off, or we would have to repeat each time. Mother nature takes care of it for us. We are happy we were able to do it this way instead of using sequesterants/chemicals and so forth.
    1st time pool owner: 16x48 Intex Ultraframe, 5061 gallons, intex SWG, 1500 gph cartridge filter (635T) , Gorilla pad, SP1091LX Hayward skimmer, K2006 and K1766 test kits, high iron well water, Poolmate Metal out, 5 gallon bucket/polyfill filter
    May 2015
    14,096
    What about the tap water from the city, any iron? Many municipal water suppliers just simply use local treated well water. If the municipal water is low iron, then I'd use that....
    Matt
