Thread: Ag ladder mat suggestions?
    New pool owner here! I have an ag pool with the steps, ive been told i should get a mat, however, they are so expensive! Are there any other options?? I've looked through other posts here but didn't really get a good answer.
    Court from sunny FL!
    18X52 symphony abg metal pool
    blue torrent 2 speed 1 hp pump
    Taylor test kit k2006
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Ag ladder mat suggestions?
    Here is some recent discussion on this topic.
    Bath mat under ladder
    Isolated Spa - 345 Gallons
    Aug 2016
    Wilmington/NC
    115
    Here the one that I use. Worked fine last year for us.
    Little ole baby pool. 14' x 42" Pro Series 3300G pool. AG Vinyl with metal frame. Currently installed are a Intex pump/sand filter SF60110 3000GPH and Intex SWG ECO8110. Filled with city water. TF100 Test kit.
    [QUOTE=Super B;1204769]Here the one that I use. Worked fine last year for us. [IMG]https://uploads.tapatalk-cdn.com/20170419/1d070a752a1895e07527ef28d043abb9.jpg[/IMG
    Thanks! Can I cut it for each leg? The larger ones would just be under it, so not sure what's best.
    Aug 2016
    Wilmington/NC
    115
    Don't see why not. I just put it under the hole bottom leg on ours
    Aug 2016
    Wilmington/NC
    115
    Here the ladder I have
