Results 1 to 9 of 9
Thread: ST1102 pump hum - time to replace?
    Apr 2017
    Huntsville, AL
    2
    Hi all,
    New guy here.
    I just replaced the capacitor and fired up our pump but still get the same hum. Is it time for a new pump?
    Here is a short video: St1102 pump hum - YouTube
    If I have to purchase a new pump will I need to buy the piece that the 4 mounts from the pump attach to, or can I re-use this piece? Is this some sort of adapter?
    I'm not quite sure how the pump is attached now without bolts being in there.
    Thanks for any assistance.
    CajunGuy's Avatar
    Apr 2016
    Louisiana
    303
    Re: ST1102 pump hum - time to replace?
    I'm not 100% positive and farrrrrrrr from an expert on here, but I just removed my motor from my pump this week and from the looks of yours...you won't be able to remove your seal plate (larger black plate with the other bolts) from your motor d/t all the corrosion on the bolts. I would try to remove the 4 outer bolts on the seal plate and see if you can get everything pulled out at once. You might be able to get by with just a new motor, seal plate, and possibly a new diffuser and impeller depending on what they look like once the unit is pulled. At this point, it may be worth looking into replacing the whole pump with a new one.
    15k Gallon In Ground Saltwater Gunite Pool and Spa w/ Overflow
    Dolphin S200 Pool Cleaner
    Main Filter Pump - 1.5HP Pentair Whisperflo connected to Triton II Sand Filter
    Spa Pump - 2HP Pentair Whisperflo w/ 2HP Polaris Spa Air Blower
    Resilience PSC3 SWCG
    Apr 2017
    Huntsville, AL
    2
    Quote Originally Posted by CajunGuy View Post
    I don't doubt it. This is a family members pump and I'm not sure about the age of the pump or for that matter, what I'm doing! Just trying to save some bucks.
    Are there "de facto" diagrams out there that tell exactly which parts I would need? I'm searching on Google Images now, and its all different models when I search with "st1102 diagram".
    Thank you
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,606
    If you can find the id plates on the wet end of the pump that could reveal the parts needed.
    (knowing the pump model)
    Dolphin E10 Cleaning Robot.
    Can you show the back of the motor with the cover off?
    Note that this is a C-face motor and not a square flange motor like the Whisperflo.
    The C-face has a motor mounting plate with the bolts on the inside.
    Support the site
    I suspect that the motor is seized. I would remove the four bolts and pull the motor assembly back so that you can try spinning the impeller. Spin clockwise looking at the impeller. Make sure that the motor is off. Note the part number on the impeller.
    Support the site
    Apr 2017
    sacramento CA
    147
    Sounds to me like your motor is seized up.
    I'd open it up an see if you can get it to spin with your hand. Spray a bunch of wd40 or liquid wrench on those bolts before you do it to clean it up and hopefully loosen some corrosion. There are other products out there too. Those bolts have seen better days.
    For a new motor you need a 56j frame. Look on the nameplate of the motor it says fr that's the frame. It indicates the correct bolt pattern of the motor. It also has the voltage and everything else you need. If you can get it off, you can take it to a shop and they can remove the impeller from the shaft. Most of the time those are pressed on, some have a set screw.
    Good times. Take care
    The impeller is threaded on, not pressed on.
    Support the site
    Apr 2017
    sacramento CA
    147
    Even better
