Thread: Filter Clogging best cleaning methods?
    Aloha all, I have the Hayward 1200 cartridge filter system which is way large for my system. I clean it and in a few hours out put is down to a trickle again. I went and bought a new cartridge and it is pumping with great flow and water is much cleaner. Soooo what in my cartridge cleaning methods is wrong?
    1: there is a lot of brown stuff on the pleats that I clean off with a pressure nose/nozzle that is the brass kind described here (shoots 40 feet or so). I get all the stuff off
    2: then is there a coating of maybe an oil (from body over time) that I do not see that is still present that I am not removing with plain water?
    3: If so, then what sort of chemical do I use to "cut" the contaminants? I see a lot of suggestions here
    4: What is the brown stuff?
    7800 Gal. 8' wide x 20' long x 7' deep
    Hayward 1200 Cartridge 7200 GPH, Waterworks 1/8 hp 2400 GPH
    Made from 20 Container Lined with "PolyUrea/Rhino Lining"
    Workshop, welding etc,+office+living area running off grid on 10kw PV
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Filter Clogging best cleaning methods?
    Aloha, yes I will try the dishwasher trick, as I do the brass nozzle and clean every pleat, but must be some hidden oils/grease clogging. ( I bought the Hayward unit with used filter cart on Craigs, so do not know the history, but bands are broken, and the top and bottom gasket are brittle and cracked, but I made new ones and attached so they will not bypass but pleats are all in good shape)
    Do the cartriges finally wear out?
    thanks
    Francis
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    eventually yes. if I were you I would get a new one.
    http://www.unicelfilters.com/pool_owner ... filter.asp
    Aloha, thanks, I am now in my first semester of Pool School, so my questions may get smarter and smarter.
    I got the new filter and yes what a difference. Now trying to clean the old one as a spare.
    Thanks
    Francis
