Thread: Dual Intex
    Apr 2017
    Bakersfield
    1
    Dual Intex
    I have dual pool. How do you used a pool sweeper withe the two small holes
    Can't you switch it up. Have the dual pushing water back on the pool. Then bigger hole to take the water out
    I have a dual intext. Can you you switch it up . Can you used the dual for blowing the water out. Then use the other bigger hole to suck the water. Out. A other thing how can u use sweeper with dual.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Dual Intex
    Hi John, and welcome to TFP,
    Sorry, but I am not clear at all on what you're asking. Can you explain the dual pool and what that means? Also, you have your question in your signature line so you'll want to remove that.
    Essential Links:
