Thread: Lower pH with solar cover on?
    Aug 2015
    Grandy, NC
    136
    Overshot Borax trying to bring up pH from 7.0, ended up at 7.8. Need to add muratic acid to lower slightly. Solar cover cause any problems? Time of day matter?
    Thanks.
    19300 gal, AG vinyl, 1 HP Pentair Dynamo two stage pump, 5 yr old Hayward Vari-Flo sand filter, pool 14 yrs old, well water, testing with Taylor K2006
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Lower pH with solar cover on?
    Ph at 7.8 is fine. A solar cover will significantly slow pH rise. Time of day shouldn't matter, unless it's after beer-thirty.
    Aug 2015
    Grandy, NC
    136
    Always beer thirty somewhere!
    Thanks.
