Thread: testing for leak in pool
    Feb 2017
    Tulsa, OK
    110
    I believe I have a slow leak in my pool because I have been losing at least 1/4" of water a day and it has not been very hot. I did a bucket test and plan to do one again soon.
    right now I am letting the water level drop below the skimmers and just using the pool main drains ( I have tow ) to filter the water so I can see if it continues to drop at the same rate so I can test if it is the skimmers or not.
    Is this a bad idea? Any problems with this?
    Tulsa, OK,Gunite inground pool - lagoon finish - 20,000 gallons
    Hot tub in one corner that is raised about 3 feet and has two spillovers into the pool
    Small side pool with two pipes that jet up water and has two spillovers into the pool
    Has a sundeck at the front
    Jun 2014
    17,327
    Re: testing for leak in pool
    Not a bad idea at all. As long as you still have the ability to move water through the pump. That way you can rule-out the skimmer line. Here are some more ideas: Pool School - Leak Detection
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,261
    tag,
    What was the result of your bucket test, and how long did you run it? 1/4" a day is not all that excessive.
    But, your plan sounds ok to me... If it stops right below the skimmers or right below the light, you'll know for sure.
    Thanks for posting,
    Jun 2014
    17,327
    tagteam, ask Jim to show you HIS bucket tester! Trust me, you gotta see it.
    Feb 2017
    Tulsa, OK
    110
    In the bucket test the pool did go farther down from my line than the bucket did. However, I did not check the inches. I plan to do it again tomorrow or the next day and this time I will measure the amount of water in the bucket in inches.
    Here is what I have been recording so far.
    4/10/17 evening 3 1/4 pump
    4/11/17 morning 3"
    4/11/17 6:00 PM 2 3/4 pump running 8 hours
    4/12/17 morning 2 1/4 Pump not running
    4/12/17 evening 2" pump ran all day
    4/13/17 8:00 AM 1 1/2 just over 1 1/2, Pump not running
    4/13/17 evening 1 1/4 + pump ran during day
    4/14/17 8:00 AM 1 1/4 - pump did not run at night
    4/14/17 10:00 PM 1" Pump running all day and a bit of swimming
    4/15/17 11:00 PM 1/4" Pump ran all day - water below north end skimmer level, a little still goes in south skimmer.
    4/16/17 1/2" Rained most of the day.
    4/17/18 1/2" Rained and was cloudy
    4/18/17 1/4" pump running all day
