Thread: Clearing Pollen
    Clearing Pollen
    Hi All;
    Had a ton of pollen this year, green dust all over vehicles, driveway, etc. Pool opened clear without any problems. But after pollen hit pool is cloudy. Running sand filter about 10 hrs daily but it seems to be taking a long time to clear.
    FC=7.0
    CC=0.0
    PH=7.6
    TA=90
    CYA=30-35
    Water is blue
    Losing 1.5 ppm FC Daily
    Suggestions welcome.
    Gary R.
    IG Pool 20,000 Gallons Gunite-Hayward 1 HP Super Pump-Doheny Discovery Pool Cleaner
    Pentair Sand Filter-Raypac Pool Heater 266,000 BTU-PoolSkim Pool Skimmer-TF 100 Test Kit
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,838
    Re: Clearing Pollen
    Welcome,Chuckles. I'm in the middle of a forest so know exactly what you're talking about. In my case, filtering 24/7 during high pollen activity helps keep me crystal clear. In your shoes,I'd bump up filter time for a few days to see the difference. Using a skimmer sock on your skimmer basket will also help trap it.
    If after a fe days the extra filtering isn't helping, there are products such as the http://slimebag.com that can be purchased with an adapter to fit on a return. That bumps up filtration a good deal...people on wells and with smaller AGP filters love em. Butthat might be overkill for your purposes
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    686
    Re: Clearing Pollen
    You can also add a small amount of DE to the filter through the skimmer. It will help the filter trap the very smallest of particles and help clear the water faster. Just be sure to watch the pressure as it will rise a lot faster since it's trapping more.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Clearing Pollen
    Ditto on living in the woods. My brown truck is green right now! If you gph Ave a 2 speed pump run it on low 24x7. My VS pump runs 24x7 in spring and fall at 1100 rpm to clear all the tree stuff. It only uses 150 watts at 1100 rpm so at 10.25c/kWh it costs less than 12 bucks per month. And I keep my FC at 10% of CYA.
    A 2 speed pump uses 1/4 the electricity to move half the water as it does on high.
