Results 1 to 16 of 16
Thread: Outdoor TV Wiring Options
    Sep 2016
    ND
    125
    I'm curious as to what people have done to conceal wiring with outdoor TV setups. Since I have seamless steel siding, and the TV will go on a wall that's over 20' tall, my options with regard to cutting into the wall or using an overhanging soffit are limited - I'm either going to have to come through the wall at the exact location where I mount my surface-mount boxes, or come up from the bottom... From what I can tell, I'm limited to low-profile flush-mount boxes for both power and my signal (I'll use CAT6 to HDMI baluns), and I'll probably have to put these either above / below the TV vs behind it.
    Has anyone uncovered a good way to keep these semi-concealed, or are I just stuck looking at the exposed surface-mount jboxes for power and LV cabling, either above or below the TV mount position?
    Derek - November 2016 Build, Fill, Cover, and Close. Starting Equipment for the first time in Spring 2017: 26K IG 20x40 Vinyl, All Pentair: IntelliFlo VST 2, Clean and Clear 420 Cartridge Filter, EasyTouch 8, IntelliChem, IntelliChlor IC60 SWG, MasterTemp 250K NG Heater, GloBrite LED lights, Autelis Automation Integration, CoverStar Leading Edge Automatic Cover, Dolphin Quantum Robotic Cleaner, Interfab G-Force 2 slide, Interfab T7 diving board
    Aug 2016
    Pittsburgh PA
    345
    Re: Outdoor TV Wiring Options
    Hard to think of options without looking at your mounting location. Can you snap a picture?
    18'x36' vinyl - 24k gal - Intelliflo 3hp VSP - Pentair C&C 420 cartridge filter - IC40 Salt - EasyTouch 8 - ScreenLogic - Raypak 406btu NG heater - Intellibrite 5G ligths - 4 deck jets - sheer descent - X-Stream Slide 2 - TF100 kit - opened spring 2017
    Sep 2016
    ND
    125
    I had to dig through the archives a little to find a picture, but this shows were the TV will go. I can fish wires through the engineered truss that I drew.
    Aug 2016
    Pittsburgh PA
    345
    So you're struggling with how to get wires from inside truss up to behind TV. And want a flush mount (picture frame) style TV mount. Maybe instead of flush mount, find low profile with enough room for a box behind it. And use a low profile box. What's on the other side of that wall?
    Sep 2016
    ND
    125
    Exactly. I don't really want the power box showing, but I also don't want to try to recess something into the steel siding. I've put up many, many TVs, but always inside on drywall. I'm kind of thinking that I have no choice but to run conduit up the outside, so it won't be a clean install regardless, so maybe it's not the end of the world if I do it that way...
    The other side of that wall is a bathroom, and where the TV is located, it's a tiled shower...there is a small chaise for plumbing there, but the floor is closed with the exception of what the plumbers cut for pipes so I still have a problem with getting vertical inside of that wall...
    Aug 2016
    Pittsburgh PA
    345
    So you don't want to cut into siding to recess box...i assume because you can't fix that spot if you decided to remove TV? Kinda perm with steel siding.
    If running conduit, maybe find a spot to left or right and run it horizontally under on the siding ridges.
    For low voltage, they sell hdmi transmitters. Put one inside and put the other end on TV. Not sure if that helps in your application but I know someone that uses it and it works. He didn't want to drill through his stone wall.
    Sep 2016
    ND
    125
    Quote Originally Posted by Veccster View Post
    Sent from my SAMSUNG-SM-N910A using Tapatalk
    Yes, I don't have the appropriate tools/material to trim it out, and then if I ever take it down, I end up having to replace a couple of 30' runs of steel siding.
    I've done lots of AV stuff - kind of a side-project hobby of mine for the last 20 years. I've haven't tried wireless HDMI recently - all of our video and audio comes from central equipment racks and HDMI over CAT6. I wonder how well it would work with steel siding? I know our baby monitors don't make it more than about 10 feet directly on the other side of the wall from the transmitter, but if your friend was using it to go through a stone wall, I would have to guess that may be similar. If necessary I could bring my transmitter signal closer with HDMI over CAT6...
    Aug 2016
    Pittsburgh PA
    345
    It's not cheap but yes, it goes through a stone wall. Unfortunately, it's not cheap.
    https://www.amazon.com/Nyrius-Wirele...mi+transmitter
    Maybe someone else has a solution. Good luck to you!
    Sep 2016
    ND
    125
    Nice! That looks pretty sweet - the only downside that I see is that I'd have to figure out a way to control my devices - I'm usually using IR repeaters that work with the HDMI-to-CAT6 baluns that I use.
    Looks like they have a different model that has HDMI pass-through, two inputs, and IR repeating:
    https://www.amazon.com/Nyrius-Transm...dp/B00OABOZYC/
    Jun 2016
    Marlboro, NJ
    194
    i am curious what you are mounting the tv in to protect it from the elements?
    that's my issue - finding something that doesn't cost 5x the cost of the tv to mount something in.
    Pool Type: In Ground, Liner. Shape: Free form/kidney
    Filter/Pump: (2016) DE Hayward 4820 / (2016) Pentair VST 2
    Heater: (2018) Raypak 406A 400k BTU
    Location: NJ. No tree/leaves overhead. Limited shrubs near/over waterfall feature
    tcrote5516's Avatar
    Jun 2014
    New Hampshire
    111
    To control them I'd grab a harmony hub though once again your aluminum siding will challenge the RF transmissions.
    - Tom
    Check out my DIY YouTube Channel @ https://www.youtube.com/channel/UCbq..._as=subscriber
    Sep 2016
    ND
    125
    Quote Originally Posted by ionizer View Post
    I'm actually not planning on mounting it in an enclosure - my plan is to cover it up to protect it from rain, and to move it inside for winter - knowing up front that this is the lower-cost option and replacement at some point in the future is inevitable. Weatherproof covers can be had on Amazon for under $50: https://www.amazon.com/KHOMO-GEAR-We...dp/B0195GXLBY/
    Everything that I've seen that's specifically engineered for outdoor use is $1,000+. There's also SunBrite TVs which look interesting, but when I can buy a run-of-the-mill 60" TV for $400, is it really worth spending $2k - $3k on a 40-something inch TV? For me, I think that the answer is no.
    I'm looking at this as being "disposable", meaning that if I can get a few years out of it, something better will be out and I can replace it then. To go along with that, I'll buy a basic (mainstream model) outdoor TV - I'm not interested for high-end features outside where it will be subject to abuse - there's different spots in my house where I'd make a different decision with regards to this, but for outside, my parameters are basically low cost because I know it won't last forever.
    Jun 2016
    Marlboro, NJ
    194
    Quote Originally Posted by dw886 View Post
    yeah, that's where I Am headed too. the one you linked to doesn't cover the bottom though, so not sure i'd want that particular one
    your mounting on the house right?
    do you know if there is any pole mounting options you've seen?
    Sep 2016
    ND
    125
    Yes, my plan is to mount on the house. I haven't seen any pole-mounting options outside of things that hang from the ceiling. Why are you thinking about using a pole - so the TV can swivel?
    Jun 2016
    Marlboro, NJ
    194
    because I want it by my pool area which is not near the house and thus there are no walls to put it on. Only option is literally mounting it on a pole somewhere.
    I could probably also use an existing pole I have for a super bright RAB LED, but that location is ideal for the light, less so for the tv....but then again, i dunno.
    Regardless, ive not really seen what I am looking for either. My other desire would be to have it come out of the ground via automation, but I only saw that for some 200" tv on some website and dont feel like dropping 1/2 a mill
    Killer95Stang's Avatar
    Sunny SoCal
    700
    I was going throigh the same hassles of trying to figure out what type of cat6 to hdmi or wireless hdmi transmitter I was going to get video feom my rack mount system outdoors. Then, Verizon did me a favor and sold its FIOS network to a crappy company called Frontier. Service was so bad, I switch to Directv which allowed me to get the mini Genie wireless boxes. Problem solved! Signal is good enough with Genie generated wifi network, that I get a great picture on the patio. The Genie vox itself ks small enough to velcro to tje back of the TV.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
