Thread: Borate - Boric Acid, should I use crystals or powder?
    Jun 2015
    Glendale, AZ
    158
    Adding borates using boric acid, should I use crystals or powder?
    Valley of the Sun, Arizona.....10k gunite/pebble (Re-surface March 2015) w/in floor Caretaker 99 cleaning heads -- Pentair FNS 60 DE filter -- Pentair IntelliFlo Variable Speed for pool -- Pentair Wisperflo 1 HP for boulder waterfall...Taylor K-2006 & Taylor K-2006C kits
    Donldson's Avatar
    NW Ohio
    3,220
    Re: Borate - Boric Acid, should I use crystals or powder?
    If by crystals you mean granular, then you want that over powder. The powder will not mix easily with the water, some will blow away in the wind and some will sit on the surface, so go with granular.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath
    Jun 2015
    Glendale, AZ
    158
    Yes, I am referring to granular....thanks I will go with the granular
    Does the granular dissolve quickly and should it be broadcast across pool and brushed?
    Donldson's Avatar
    NW Ohio
    3,220
    It dissolves pretty quickly, you can either slowly pour it in front of a return or broadcast it, brushing is never a bad idea after you do it. While it is a fairly weak acid you don't really want to leave anything sitting on the bottom of the pool too long.
    Jun 2015
    Glendale, AZ
    158
    Donldson...thank you kindly, will follow your suggestions
