Results 1 to 14 of 14
Thread: Daily bleach usage?
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Daily bleach usage?
    I have not yet turned on my SWG, and have been using 10% bleach from Walmart. Ran an OCLT test last night and no loss. I am keeping my Chlorine target at 7.5-8 while using the bleach. I am adding 24 oz of bleach a day to keep at target range. My CYA is at 60, and I will be raising it to 70 when water temps hit about 75, and I turn on SWG. Water temp is at 67 this morning. Does that amount of bleach added each day sound about right?? I should mention that I LOVE MY SWG, as this hauling of bleach pretty much sucks!! HA
    Mark
    20'x28' IG, Vinyl, (Sept 2015) 14,900 Gallon, 3'4 to 5'6 deep, Jandy Proflo 1.5 HP, 220v, 2 speed pump, Waterway Carefree 27" 400 LB Sand filter, Digital Nano plus SWG, TF-100 test kit /speed stir. Dolphin Primal x3 robotic cleaner
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Re: Daily bleach usage?
    Don't look at it as oz of chlorine added, but rather FC ppm replenished. Most pools average 2-4ppm FC loss daily, more with heavy use/hot water temps, less with low use/cold temps.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Thanks Dom!
    Mark
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    It wont hurt to try and run a little lower residual until it warms up for the Cell. You are on top of this well enough that you will notice anything that starts to happen in plenty of time. I'll bet you can, and might be surpised what you get away with. In a well maintained pool like yours, and Algae outbreak won't happen overnight.
    Essential Links:
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Pat, I am not exactly sure what you mean? Are you saying I can keep FC number down some during this period? If so, what would you say that number could be? I appreciate it!!!
    Mark
    Apr 2017
    Maine
    231
    Your swg should generate chlorine once water is above 60
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Quote Originally Posted by Chemnut View Post
    Yes I know that, and thanks. I am just trying to save some hours in the springtime by using liquid chlorine.
    Mark
    Apr 2017
    Maine
    231
    I'd be curious to see how much that liquid bleach is costing versus chlorine from the swg. In my area bleach isn't cheap is my reasoning for getting swg up n running as soon as I possibly can.
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    At 3.64 a gallon and using 24 oz a day, a 128 oz jug of 10% bleach is costing me about .33 cents a day. Im no math wiz, but that's what I came up with.........HA! I have about 5000 amp hours on my cell, so I am just conserving some.
    Mark
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Quote Originally Posted by kywildcats View Post
    Yes, and I am saying its possible you might be able too since you are so on top of it, and you're tired of hauling. If you kick it down a couple of PPM at a time, keep it there a few days and its not enough FC, you'll be there to see the pool change. If it starts going hazy on you, simply kick the FC back up to where you had it. Blooms don't pop up up without warning in well maintained pools. The water gets hazy, then cloudy, and then starts to turn Green.
    Essential Links:
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Quote Originally Posted by Patrick_B View Post
    I will try that.......thanks so much!!!
    Mark
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Cool, let me know how it works out. I'll be curious for sure.
    Essential Links:
    kywildcats's Avatar
    Jul 2015
    Mayfield, KY
    609
    Pat, I have been keeping my FC target at 6, instead of 7.5-8 and everything is working fine. This Kentucky weather is out of control with wind and rain the last 5 days, so my water temp just wont come up. It is at 61 this morning, all though it did reach 71 last Thursday. I am saving a lot of bleach and hauling during this time, but I am ready for things to WARM UP!! Thanks again!
    Mark
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I was wondering about this the other day. Great to hear man.
    Essential Links:
