Results 1 to 9 of 9
Thread: What to do when pump has to be off for a few days?
    Mar 2017
    Syracuse, New York
    35
    Got the pool open last weekend, and this week getting the heater installed. Electrician has to spread work over two days, not back to back, and the pump will be without power during that time.
    What can I do to make sure the water stays okay without filtering for those few days?
    Too cold to swim anyways, but want to make sure...
    Pool Size: 18,000, In Ground, Vinyl.
    Hayward Sand Filter, Hayward Pump
    Hayward 110,000 heat pump heater
    TrueClear Salt System
    domct203's Avatar
    Jun 2015
    CT
    3,898
    Re: What to do when pump has to be off for a few days?
    Quote Originally Posted by tbkurtz View Post
    It's most important that you maintain the chemistry of the pool.
    Next you'll need a way to circulate the water. You can rent a submersible pump, and use that to keep the water moving, or thoroughly brush the pool a couple of times each day, especially after adding any chemicals.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    I would also raise FC to shock level for your CYA, FC/CYA Chart
    Jul 2015
    Central Valley CA
    1,166
    If you have a sump pump you can put in to circulate the water and chems do that, if not brushing well after daily chlorine adds should do the trick to mix the chlorine and keep the water sanitized. Filtering is largely about water clarity while chlorine is largely about sanitation. You can get away with out filtering much longer than you can without sanitation.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,752
    Buy a cheapo Intex cartridge system and just hang the hoses into the pool. You might have to prime it since it's designed for above ground pools, but once you get it running, just keep it on 24x7.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    What is the water temp? If it's around 50 probably nothing will happen,
    but you could dump in a gallon of bleach in the deep end, spread around
    the perimeter then brush the pool to stir it around.
    Dolphin E10 Cleaning Robot.
    Mar 2017
    Syracuse, New York
    35
    Quote Originally Posted by borjis View Post
    As of typing this, its 57.6 degrees. Nice sunny day, it got up to 60.5 yesterday in the sun. I'd say averaging low 50's.
    As of last night, FC was 7.5, CC was 0 - CYA is 60. Was planning measuring FC again tonight and added some bleach.
    I don't think I want to buy a piece of equipment, so if the consensus is that keeping it sanitized, and spreading chemicals by brushing, will do the trick for a cold pool for a couple of days - that's probably what I do.
    These forums are awesome... thanks for all the replies.
    Jul 2013
    Long Island, NY
    556
    Yeah your pool will be fine for 2 days with your FC at 7.5 and the pool temp of 60 degrees.
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    Ya that should be fine. Sounds like you know what to do to keep the FC level proper.
