Thread: help identifying spa blower size
    Mar 2015
    Richardson
    16
    Hello,
    We have a spa blower that is shutting off after a few minutes. I plan on removing it and just trying it off the pipe, but if it has gone bad, I need help to identify what size. It is a Polaris Anzen? (it is a old and brown metal unit with a domed top) but all the numbers have faded off the sticker. It appears that all these blowers are physically the same size, so I have no idea how to tell them apart. I should be able to determine voltage after I trace it out. Are there any other numbers on the unit somewhere? Can it be taken apart to see what it is?
    Is there a trick to get it off the pipe to test it?
    thank you
    Don
    Dallas,TX
    27,000 gallon, dark gray Sunstone quartz aggregate plaster, Hayward DE filter, Dallas TX
    Jan 2017
    Orlando/FL
    124
    Re: help identifying spa blower size
    It should not be glued to the pipe - but it could be. Usually the blower just slips over the PVC pipe and there is a screw used to hold it in place.
    I goggled "Polaris Anzen" and there is a lot of info (manuals, pictures, etc.) available so you should be able to match up yours and find the correct model number.
    I would expect the voltage to be 120V regardless of the model. The difference between a 1 HP and 2HP model would be in the amperage draw, not the voltage.
    How is the blower switched on now - through Pool control panel or with an external on/off switch?
    20K gal In-ground pool with raised Spa overflowing into pool; two Jandy Sheer Descent waterfalls; Pentair IntelliTouch i7+3, IntelliChlor, IntelliPH, 3 SAM/SAL lights, Pentair FNS60Plus filter, two 1.0 HP WhiperFlow pumps, Jandy/Compool auto-valves, RayPak Heatpump, RayPak 406A LP spa heater, Polaris 360 PS Cleaner. Patio and deck lighting by Volt; Volt 600W landscaping transformer; Webber grilling station
    Mar 2015
    Richardson
    16
    Actually, even though you can't see the markings with a naked eye, my wife took a great picture with Samsung Galaxy phone and when it is blown up, I can faintly make out the model number and HP. it is a 240V 2hp model. , #56603.
    Jan 2017
    Orlando/FL
    124
    I'm learning. I see now that this model is available in either 120V or 240V for the entire range (1HP, 1-1/2HP, and 2HP). http://www.jandy.com/~/media/zodiac/...s/1-5-1420.pdf
    Do you "flip a switch" to start blower or have it controlled by pool automation/control?
