Thread: Hayward 1hp Powerline pump, single phase, capacitor connections
    Jul 2016
    Modena, Italy
    3
    Hello, This is my second attempt at trying to post this question. As it does not appear, I must have made a mistake. Anyway, having removed my Hayward pump for the end of last season, I came to refit it but found that I had lost my wiring diagram. Normally, simple live, neutral and earth connections are all that is required. This time however, I noticed that one of the 2 black wires coming from the capacitor was not connected to anything. The other black wire is connected to the terminal block together with the red wire coming from the motor. Can anyone help me with how I should proceed or will I have to resort to an electrician. Many thanks
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Re: Hayward 1hp Powerline pump, single phase, capacitor connections
    Do you have any pictures you can post of the wiring you are referring to or the model number of the motor?
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
