Results 1 to 14 of 14
Thread: Permanently Closed Return?
    Mar 2017
    Syracuse, New York
    35
    Opened my pool for the first time with the help of TFPC - so far so good.
    I have a bit of a mystery I hope people could help me solve/investigate.
    There is a return (maybe) that I can't open by hand, and I'm wondering if perhaps it's permanently closed. There doesn't seem to be a return pipe from the pump/filter.
    Here's the return - can't open by hand.
    Attachment 59386
    Here's the equipment - two intakes, one return. What's the second return connected to?
    Attachment 59387
    Pool Size: 18,000, In Ground, Vinyl.
    Hayward Sand Filter, Hayward Pump
    Hayward 110,000 heat pump heater
    TrueClear Salt System
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Permanently Closed Return?
    Sorry, I'm not clear at all on this one. Do you mean the red ball valve is the one you cant open? Those types do get old and stuck open or closed quite commonly. I have no idea what that leg is there for, but that would be a very easy valve to replace if need be.
    Essential Links:
    Mar 2017
    Syracuse, New York
    35
    Quote Originally Posted by Patrick_B View Post
    Sorry, I should have been more clear.
    The first picture is in the pool - I can't take out the plug by hand. I was afraid I would hurt it if I really cranked on it. But I got wondering, what feeds that return? If you look at the pool equipment, there are two intake pipes (with a valve) but only one leading away from the filter (presumably to the return in the pool that is working.).
    That small line (with the red ball valve) feeds the water slide, it leads off like that because it appears to be a repair job - I assume the under ground feed for the slide broke, and they didn't want to dig it up to repair.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Ok, I saw that too, and sorry to say I just dont know. Hopefully someone will before too long.
    Essential Links:
    Mar 2017
    Syracuse, New York
    35
    My fear is that perhaps the return broke, and rather then dig it up then just eliminated it.
    What could happen if I grab a wrench and get that plug off the return? Could anything bad happen besides some leaky pipes under ground? Is there any special process for permanently closing a return line that I might undo?
    I'd like to get that cap off, turn on the pump, and see what happens.
    -Tom
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    544
    Quote Originally Posted by tbkurtz View Post
    -Tom
    Just use a screwdriver to get it off. I can't imagine it would do any permanent damage and you could just plug it back up. If the pipe leading to it is leaking / broken it will have been isolated between the pump and the return already or you would be losing water. You may very well find it is piped into the other return and works!
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Feb 2012
    Maryland
    400
    Quote Originally Posted by ship of fools View Post
    Totally agree ... stick a screwdriver in long ways and twist, should come open.
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    I would suggest Channel Lock pliers instead. IF I was somewhat confident it was threaded in. It probably is...I just don't know, but if it does, I'd do that instead of a screwdriver...especially with a vinyl liner you could slip and poke a hole in.
    Essential Links:
    Nov 2011
    Albany, NY
    544
    As Gumby said if you use a screwdriver do it long ways but i see your point (no pun intended!)
    Haywood Sand Filter
    Vinyl Liner
    Mar 2017
    Syracuse, New York
    35
    Thanks guy. I just used the side of a screwdriver to get the leverage to open it, and it bubbled out and water started flowing from the pump. I guess it just splits underground somewhere.
    Just in case, any pointers on what to watch for as far as leaks go?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Awesome, I am glad it worked for you. We just err on the side of caution here a lot. I could see it would accept the length of the SD shaft, but I was just imagining one of those DOH! moments.
    Essential Links:
    Feb 2012
    Maryland
    400
    For future use, get a hayward inlet seat removal tool. They are very cheap, like $5 or so, and work great without fear of yanking a hole in the liner. I too used screwdriver but was always worried, this little tool makes it easy without worry.
    As for leaks, i'd say watch water level for a bit.
    Nov 2011
    Albany, NY
    544
    The removal of that plug shouldn't change anything if the water is flowing from it now. That means it was connected to your pump / other return all along and water would have leaked out of the pipe to the return. The fact that it was plugged where it enters the pool wouldn't stop any leaks from the pump side.
    It is common to have multiple returns fed off one pipe from the pump. Mine has 3 returns fed off one pipe and and the 2 returns in the stairs are fed off another. I can shut either off.
    Better safe than sorry but my guess is you will be fine.
    Haywood Sand Filter
    Vinyl Liner
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Agreed, that should not leak. If anything there is less pressure on the plumbing behind the fitting now.
