Thread: Aquapure 1400 backboard or transformer problem
    Sep 2016
    Spring, Tx
    58
    Hey everyone, need some advice / help again. In short I went out Friday to check my chems to find there was next to 0 chlorine in my pool. So I go and check my panel and it shows "LO" chlorine production and a 123 error code, which I looked up and that indicates a low power condition. So I got my PH in check and then added some liquid chlorine to get a handle on that. So I'm good with the chems back in balance. However I broke out my test manual that shows me the test points and what voltages I should have. I attached the link below. So here is my data,
    Backboard Test Points
    1 - 8: 75 VAC, actual reading 78
    2 - 6: 65 VAC, actual reading 67
    3 - 6: 21 VAC, actual reading 20
    4 - 5: 120 mV, couldn't get a reading on my meter, could be user error.
    While the cell is on I tested under load(green and black)on backboard I should get 22 - 28 volts. I get 4.
    While the cell is on I tested the power cable to the cell and again I should get 22 - 28. I get 4.
    Front board tests
    holding R-Temp & Salinty should be 2.8, I get 2.7
    holding Pool Temp & Salinty & R-Temp, should be 75, I get 74 degrees.
    holding H-Temp & Salinty & chlorine prod rate arrow down, I could not get a reading just beeps
    Based on the manual I did not understand where to test the transformer. So that's my main question. Power flows into the transformer from the breaker, and then into the backboard and out to the cell correct? If so, does this mean I have a bad transformer or bad backboard? Also do I need to be concerned, with these voltage deviations?
    I hope this is enough information to find a resolution, but if not let me know and I'll try and get it.
    Manual I used
    http://https://images.inyopools.com/...rror-codes.pdf
    Danny ( aka danman ) :: MyPool: 18k gallons;Jandy Stealth 2.0hp; IG Pebble Tec; Cartridge; Saltwater; built 2006; Taylor K-2006 test kit; Saltwater (aquapure PLC1400) cell; Polaris 280;
    Re: Aquapure 1400 backboard or transformer problem
    What is your actual salinity as tested by a good salt test kit like a k-1766?
    What is the water temperature?
    What does your box show for temperature and salinity?
    How old is the cell?
    I suspect that the center pin has disconnected from the center plate.
    Pull the cell and look very carefully at the plates using a good light. Check for eroded plates.
    Feel the center pin to see if it's loose.
    "LO" means low temperature cutoff.
    Support the site
    Sep 2016
    Spring, Tx
    58
    my kit won't test salinity, I actually just ordered the taylor K-2006 and that should be here on the 25th. Water temp is around 77 - 79 at the moment. the box shows (at the panel) a salinity of 3.1, and a temp of about the same. I was told the cell could be 4 yrs old, but I'm unsure. last august I replaced the tri-flow sensor.
    When you say center pin from the plate what does that mean? Does that mean inside the power cord or inside the cell? I had the cell of this saturday, because I read that if it was dirty that might cause the problem but it looks really clean to me.
    I can go check the pin on the top and see if it's loose.
    Why would I get the "LO"?
    thanks for the response.
    Check the plates for erosion. You have to look very carefully at the plates with a good light from both ends.
    The serial number will tell you the age of the cell. For example, a S/N starting with F12 would have been made in 2012.
    There are 3 pins that stick out of the cell. The plug has 3 holes that go over the pins.
    The center pin is welded to the center plate. The two outer pins are welded to the outer plates.
    Typically, the plates will erode where the pins connect and the the pins will lose contact with the plates, which can cause the low current error you're seeing.
    Support the site
    Oct 2007
    Parkland, FL
    753
    Quote Originally Posted by danman View Post
    Front board tests
    Manual I used
    I believe you can measure the voltage out points to the cell with it disconnected from the board as long as the unit is actually in on mode. Set it to 100 percent and test the connections straight on the board with the cell disconnected. It sounds like the board is bad. When I fixed mine, I found used ones on ebay for around 80 dollars. I had to do the board and the transformer since the plug connecting them had melted.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Jun 2018
    Folsom CA
    4
    Quote Originally Posted by robl45 View Post
    I'm on my 3rd backboard. I bought a new cell and sensor last year. They are clean and the pins and cable look good. When I got the 123 code I replaced the backboard. Everything was fine for a month. Now I'm getting the 123 error code again. When I went to check it out the pin connector was melted on the two cables coming from the transformer. Is the problem with the transformer or downstream(cable, connections, sensor, cell,etc)
    Any help is greatly appreciated
