Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: No CYA green pool - what to I do first slam or add cyanuric acid?
    Apr 2017
    Jonesboro ga
    13
    FC 3.0
    CC 0
    PH 7.6
    TA 140
    CH 100
    CA 0
    SC 2000
    use my Taylor K 2006 daS fmd and k 1766. Live just south of Atlanta.
    appreciate help and advice! First year trying this method and I am a newbie I have stocked up on 10% bleach from Walmart today
    Ready to get my pool clear. Just ordered a new dolphin premier pool cleaner which will be here tomorrow
    Thanks!
    Bill and Robin
    33000 IG vinyl liner. Hayward salt generator.
    Jun 2014
    17,323
    Re: No CYA green pool - what to I do first slam or add cyanuric acid?
    Hello and welcome to TFP! (First reply posted in error). See next post for proper applications with green pool.
    Hope that helps. Nice to have you with us.
    Apr 2017
    Jonesboro ga
    13
    Pool is dark green in the deep end. Pretty sure there is algae. I'm sure I need to slam but with no cya not sure where to begin.
    Bill and Robin
    Jun 2014
    17,323
    In that case, change of plans. CYA of "30" and FC of 12. Get that stabilizer in there first though to protect the pool surfaces.
    Oh, before increasing the FC, make sure to lower the pH to 7.2. Review everything on the SLAM page (link below) and you'll do fine. Good luck!
    Apr 2017
    Jonesboro ga
    13
    Thanks! Cya socks are in the skimmers and I added Muratic acid to lower ph. I am so excited for pool season this year!
    Bill and Robin
    Jun 2014
    17,323
    Outstanding! If you have any questions or problems, just let us know.
    Apr 2017
    Jonesboro ga
    13
    Still waiting on cya levels to rise. Ph is at 7.2. Adding two gallons of bleach at night. Pool is still green. I have been brushing the pool daily. Just got our new dolphin premier robot. I know there is still debris in the deep end and can't get to it with the net. We have a hise bass vacuum we have used but it is slow. Should we wait to put the robot in the water until the pool clears up to use the cleaner?
    Thanks
    robin
    Bill and Robin
    Jun 2014
    17,323
    I would be careful about dropping the Dolphin in there if you're not sure about the amount of bulk debris. Folks usually rely on raking/brushing to sift-out debris until they can see (somewhat) or to feel confident there's nothing too large down their for a Dolphin/Robot cleaner.
    Now the CYA should've increased by now since you added socks two days ago. I'm assuming the granules are all dissolved? Are you seeing ANY increase in CYA? Does it appear close to 30? Are you confident in doing the CYA test? If there is no increase or you are not sure about the test, let me know and we'll adjust accordingly.
    Apr 2017
    Jonesboro ga
    13
    Just tested cya and no cloudiness. I had new reagent since I ran out. I tested end of last season so I think I am ok with that. Socks are getting smaller. We added one gallon of liquid cya yesterday hoping it would help. I am going out and squeezing them as much as I can. Thank goodness I have my POP.
    Bill and Robin
    Jun 2014
    17,323
    B&R, the liquid conditioner should've registered by now, so I'd like for you to do the following:
    1. Begin your SLAM and dose FC up to SLAM level. If your CYA test is showing as zero, it may have converted to ammonia, so use a SLAM/Shock FC of "10". Do not add any additional CYA at this point.
    2. Retest FC at 10-minute intervals.
    a. If FC loss is greater than 50% (drops below 5ppm), add bleach immediately to bring back FC up to SLAM level and continue retesting FC @ 10-minute intervals.
    b. IF FC loss is 50% or less (5 or above), add FC to bring back up to SLAM level. Go to Step 3.
    3. If CYA is still below 30 ppm, add enough CYA to bring level up to 30 ppm.
    4. Now increase FC slightly back to "12" and continue SLAM as directed in the SLAM article until the SLAM Criteria of Done are met. Test as directed in the SLAM article - no longer need to test FC at 10 minute increments at this point.
    It's very important you test every 10 minutes in that beginning portion. Follow those steps to the letter and it should get your water back on track so that you can do the SLAM properly. I suspect the winter conditions and lack of CYA created more of an aggressive situation in your water which is why we need to follow those steps.
    Apr 2017
    Jonesboro ga
    13
    Thanks! Will update.
    Bill and Robin
    Apr 2017
    Jonesboro ga
    13
    Quote Originally Posted by Texas Splash View Post
    Ok ok tested this am.
    Fc 1.5
    cc 1.0
    cya still below 30
    added bleach each and waited 10 minutes
    no change in levels
    Added more and still no change after ten minutes.
    How long one after adding bleach do I start the testing?
    The the pool color does look better
    Bill and Robin
    30,941
    How much bleach are you adding? How much CYA did you add? Are you trying to SLAM your pool? You need to be more specific.
    Jun 2014
    17,323
    So when you say "no change in levels", are you saying that after adding bleach, the FC level never rises? It should take about 4 gallons of "10%" strength to raise your FC from 0 to 12. I just want to make sure.
    Apr 2017
    Jonesboro ga
    13
    I put in five 10% bleach and tested after ten minutes . I used 10 mi sample and it only took 3 drops to turn clear. So that's 1.5 right? This is trying my POP lol.
    Yes if u see above. The cya was not coming up so Texas splash said to start the slam. It said to test every ten minutes. I haven't seen a change. Going to check again soon. Had to take a phone call for work.
    Thanks.
    Bill and Robin
    Jun 2014
    17,323
    Hummmm Lets ask a couple more questions because something's not right.
    - Is all that bleach from Wal-Mart (Pool Essentials)? Any chance it's old or was stored outside where it may actually be much less strength? Bleach bottles "should" have a Julian Date on each bottle. Today's Julian Date is 7110 (2017 - 111 day).
    - 10 ml sample w/ one heaping scoop of powder is correct. Number of drops divided by 2, so your 3 drops does = 1.5.
    - Any chance your pool volume is actually larger than 33K?
    - In the past, have there been any other pool store products? Some products can impact FC testing.
    Apr 2017
    Jonesboro ga
    13
    Walmart bleach. I purchased at two different locations. Some do not have the stamp and a few have 17 10...
    33000 should be the volume
    no pool store chemicals since last July I finished the pool year with TFP last season
    should I add four of the 17 dated bottles? How long does it take to show up? The green pool color is getting lighter.
    Thanks!
    Bill and Robin
    Jun 2014
    17,323
    Okay, so based on our last discussion, we confirmed how much CYA was previously added (1 gal of liquid and about 2 lbs granular), and we suspect that CYA is still low and/or there's a possible ammonia issue. Because the FC is crashing so hard, we'll continue with the 10-min drill, using an initial 3 gallons (or 3 Gal 1 Qt) of 10% and continue to perform that 10-min drill in an effort to get the FC to reach and stay at "10". With a vinyl liner, we don't want FC too high with little to no CYA. Remember that once the FC begins to hold, you won't need as much bleach to reach the desired FC level. 3 gallons & 1 Quart takes FC from zero to 10. One gallon of 10% should increase FC by about 3 ppm.
    Once you are able to break through that wall and get the water to hold FC between 6-10, then we can increase the CYA some more and you'll be on the road to a productive SLAM. We'll watch for updates. Good luck!
    Don't forget to takes pics each day!
    Apr 2017
    Jonesboro ga
    13
    So the free chlorine is still not holding. Cc is at 4. I went to get more bleach and burn some reagent cause I am almost out of reagent. Ordered some from here. The pool store near me was out. I took out my other less reliable kit (Clorox). And with four drops it is dark yellow >4 and with two drops it matches the 4.0. So maybe it is at 8??? Wonder if something is wrong with my test powder or reagent?
    I also purchased a leaf rake and have cleaned a bunch out of the deep end (pine straw). I should have buff arms by June with all the brushing etc.
    Robin
    Bill and Robin
  20. Back To Top    #20
    Jun 2014
    17,323
    The powder & drops can last a solid season and a bit longer if it was always stored indoors and away from direct sunlight. The fact that your FC is staying low and CC shooting-up really shows your water is struggling to fight back. Shame you're about to run-out of reagents. Something else I thought about later .... you might consider on your next bleach run grabbing some of the regular Great Value bleach at Wal-Mart. I know that stock usually gets re-stocked so it should be fresh - just in case. Just remember it's 8.25% though and not 10%. I hope you have enough reagents to break-through this stubborn part so you can at least be ready for the normal SLAM. Keep us posted.
