Thread: Suggestions for large amounts of leaves in pool
    Sep 2015
    owasso, ok
    41
    Hello! We have very high winds here in Oklahoma, sometimes up to 25 MPH. The leaves in the pool are driving me insane (and its a short trip lol). We have Photinia (sp) bushes nearby for privacy and when the wind blows the leaves cover the pool. We empty the skimmers prob 10 times a day on these days...which is a lot in the spring.
    Question--we are going on a 10 day vacation in 2 weeks and we are very nervous about leaving our pool unattended due to this issue....our neighbors will also be gone at this time....we don't want to turn the pool off but was wondering if they make any kind of guard for the skimmer so at least it wont fry the pump from overworking? Or some other kind of topside skimmer?
    Any suggestions would be very much appreciated.
    Hayward Aqua Rite Salt pool
    Dolphin cleaner/PoolCleaner
    Pentair Triton II filter
    Heater
    approx. 24000 gallons
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Re: Suggestions for large amounts of leaves in pool
    Hi Neighbor! Is a leaf cover an option for you? I don't have one but I have heard of them... Maybe one of the experts here has first hand knowledge of using one.
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,152
    +1 on the leaf net suggestion.
    Sep 2013
    Nashville, TN
    405
    I built some small skimmer covers out of small PC and plastic mesh for gardens, they are basically a box slightly larger than the skimmer and I used some Velcro run through the skimmer trim ring to hold them on. I with it sticking out a couple inches I don't have to worry about it covering up the skimmer completely. In the winter we get an enormous amount of leaves from our neighbors' oak trees and it is easy to net them off the bottom than empty the skimmer every hour around the clock.
    18x36 Vinyl, sports depth, 8' Roman steps at each end. Hayward 1.5hp 2speed pump, catridge filter, 2 skimmers, no main drain, 3 SR Smith Treo LED lights
    Sep 2015
    owasso, ok
    41
    Sseaman that sounds perfect. We do have a leaf cover and used it all winter but its 80 degrees now and the cover is off and these high winds are brutal. We also get construction debris from the neighborhood under construction too its awful! Ill give it a try!
    Heater
    Jan 2012
    'burbs of Augusta, Georgia
    8,556
    Do you have a main drain? Make sure that it is open also so *if* the skimmer gets so full that it impedes the water flow to the pump, that your main drain will keep the pump fed with water also.
    Please add to your signature if this is an inground or above ground pool. Thanks
    Yippee
    Skippy's Pool Cooler --> Skippy's New Fountain Our Build --> Our Pool Solved Our Sloping Yard
