Results 1 to 7 of 7
Thread: Change to DE Filter from Sand Filter or not?
    May 2016
    Greenville, SC
    18
    Question Change to DE Filter from Sand Filter or not?
    So this year I've decided to swap out my single speed pump for a Hayward VS Max-flo. Hoping it's going to save me some bucks in the end. Hopes.. I've also bought the Hayward AQR15 SWG system. Going to have all this installed this weekend hopefully.
    Couple questions. (and yes I've been reading and reading and watching youtube video after youtube video and I'm tired of researching!
    My filter is a sand filter and it's 21" I believe Hayward SP210T or something like that (off the top of my head) Anways.. the filter is only 3 years old. And I was curious if I should swap out my filter while I'm at it and get better filtration and move to a DE filter or just keep the sand filter?
    I will oversize it either way so I can get more filtration.
    My plumbing is 1.5" and I have about 16k gallons. I was leaning towards the Hayward DE4820 Pro-Grid 48 SQ. Ft. Vertical DE Pool Filter.
    I just would like something that's going to make my life easier
    Opinions/Recommendations?
    16x32 15,300k Gal. IG Vinyl
    Hayward MaxFlo VS Pump, Hayward S210T" Sand Filter, Hayward AquaRite AQR15 SWG, Hayward TigerShark QC Automatic Robotic Pool Cleaner
    Pool was installed Aug 2014, Taylor K-2006, City Water
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Change to DE Filter from Sand Filter or not?
    Sand filters are arguably the easiest filters to operate. No cleaning cartridges, no recharging DE or cleaning grids. If you're looking to make your life easier, I wouldn't switch to a DE. If you think you really need better filtration, then go with a DE. A good compromise is to add some DE to your sand filter to see if that changes things at all for you. See: Pool School - Add DE to a Sand Filter
    Welcome to TFP!
    Isolated Spa - 345 Gallons
    JoyfulNoise's Avatar
    May 2015
    14,083
    DE filters are not easier, just better at fine particulate filtration. Mine is very much oversized in comparison to my pool volume and so that means I simply tear it down twice per year (I don't backwash) and it performs flawlessly....but a deep clean/tear down, when done as meticulously as I do (to satisfy my mild OCD), takes me a good 4+ hours. It's by no means easy, just the pain is limited in frequency.
    As long as there are no serious plumbing issues or mismatch between the filter size and pump HP, ditching a 3 year old sand filter is definitely a waste of good money. A well-built sand filter can perform quite well for decades making them quite possibly the cheapest piece of equipment you'll ever own.
    Let me ask you this - when was the last time you deep cleaned the sand filter? That link will bring you to an excellent post about how to go about doing a deep clean. People are often quite amazed at the amount of "gunk" that comes out of their supposedly backwashed and "clean" sand when the do a deep clean. It's also an effective way to break up sand channeling which can cause huge performance hits to the filter.
    Matt
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    I have the Hayward ProGrid 72 sq ft, definitely oversized for my pool but have only needed to backwash twice since the build was completed last July. I like it so far, but haven't done a breakdown clean yet... I know Kim really likes her sand filter and adds some DE to it to "polish" the water. That option might make your life easier than having a DE filter, since you have to add DE every time you backwash and do a full breakdown clean 1-2x/yr.
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    May 2016
    Greenville, SC
    18
    Quote Originally Posted by JVTrain View Post
    Welcome to TFP!
    Yes, I have read about adding DE to a sand filter. I think I'll give this a try.
    I have never heard of deep cleaning a sand filter but have watched the video and will give this a shot this weekend
    Quote Originally Posted by Nursenini View Post
    Helllllooooooooo Nurse! Ha!
    Thanks everyone for your input. It's really appreciated. I think I'll just hang tight with my sand filter for this season and see how it goes.
    Also, after reading the "Filter Sizing" chart I'm wondering if the installer undersized my filter!
    Thanks again everyone!
    Feb 2014
    Central Minnesota
    5,080
    Filters installed by contractors are usually undersized, unless the pool owner specifies otherwise. Upsizing the filter above the "industry recommended" size makes them more efficient and less work to clean/backwash/etc. Your filter is fine, it just will need backwashing more often than say a 24" or 27" filter with 300 - 400 pounds of sand rather than ~200. DE does help a bit and I add a little bit after every time I backwash. My 20 pounds of DE I ordered should last me until retirement...
    May 2016
    West Bloomfield, MI
    757
    You must be a lot younger than me - I figure I have a lifetime supply. I have zero complaints about my sand filter. It's the only filter I've ever owned, but it's the only filter I want to own.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
