Results 1 to 7 of 7
Thread: Circupool 240Volts
    Feb 2017
    Tampa
    25
    Circupool 240Volts
    Had some questions for anyone who has a Circupool SWG or even knows about converting from 220 volts to 110.
    Water values are all fine so we called Circupool as our new SWG is running but producing no bubbles. Was told our SWG is 240VAC and will run but not produce chlorine at 120 Volts. We had the SWG installed not realizing it was wired into the timer and is 120VAC. Voltage on the Circupool listing on Ebay stated 110-240v so we thought we were all set.
    Wondering if anyone else has had the problem with Circupool and/or if it is practical to try and convert everything to 240 volts or if we are better off exchanging the unit?
    Thanks
    40x24 round/kidney shaped, IG 28k gal, Built in 82, 2017 Resurfaced pebble tec. Hayward DE Filter DE2420 1.5hp, Hayward SP0710XR50 Vari-Flo Pool Valve, marathon motor 1.00 HP, 1.50 SF, 1.50 THP, Circupool SJ Series 40,000 and Dolphin nautilus pool cleaner.
    Jun 2011
    Long Beach, CA
    2,891
    Re: Circupool 240Volts
    There should be instructions on what you need to do to run it on 120V. It is factory set to run on 240V but it will run on 120V.
    22,703
    Circupool has a number that you can call, and they'll instruct you on how to convert it from 240v to 120v.
    Basically you move the wire from terminal J12 to J11 and from J8 to J14. You may want to call them to make sure that's correct.
    Please post back if you find it different than that.
    Feb 2017
    Tampa
    25
    Thanks, we were able to switch it over following the diagram inside.
    22,703
    Can you tell us what you did, so that it may help people in the future? Was it the moves I posted?
    Thanks
    Feb 2017
    Tampa
    25
    There is a diagram inside showing how it is wired to the transformer. There is an white plastic area where four wires are screwed into the top four screws. The 220V has a cable going from the bottom of the 2nd to the third wire while the 110V has a two cables one going from the bottom of the 1st to the second and another cable going from the bottom of the third to the fourth. I'll try to post a pic later.
    Feb 2017
    Crown Point, IN
    6
    Quote Originally Posted by TomLane View Post
    Sorry to revive an old thread but I think this is needed info because this is the thread that comes up on google search.
    Circupool tells you to go to their help site to convert the unit from 220 to 110, but there is nothing on their helpsite and their support couldn't answer any questions just told me to send it in. ( I did not want to open it for fear of voiding any warranties, I am an Electrical Engineer, so I knew it could be re-tapped, but anyone can do this who has a #0 flat head and a Torx bit and some scrap wire)
    For anyone else wondering how to do this.
    FOR THE NEWER SJ MODELS AT LEAST DO NOT FOLLOW CIRCUPOOL YOUTUBE INFO!!
    Do not remove the back cover, you are just giving yourself more work...
    Remove 4 torx screw, 2 in each side of the unit. I believe they were T10.
    From there on the bottom right you see the transformer tap. You are moving the jumper that comes stock on 3--2 to 1--3 and then adding your own jumper on 2--4.
    Code:
      220V                      110V
     1    3     2      4        1   3      2    4
           |___|                |___|      |___|
    Keep the other 2 wires that are already installed on 1 and 4 in their same places.
    I have also included pictures, the above is for someone to see in quick reference or if pics aren't working.
