Thread: Easy Touch reports 0 ppm? IntelliChlor shows good salt
    Sep 2015
    Roanoke, TX
    4
    Just recently, my EasyTouch 8 (under Diagnostics->Chlorinator) reports 0 ppm/OK- No Errors. IntelliChlor inline was showing low salt, so I added a bag and it went back green, but ET8 still shows 0 ppm. Any tips? It was working a few weeks ago, when IntelliChlor was blinking red for low salt and ET8 reported something along the lines of 2400 ppm. All was good after I added a bag etc....
    To add, the entire system is about 6 months old. Pool was finished last August.
    Oct 2015
    San Diego, Ca.
    805
    Re: Easy Touch reports 0 ppm? IntelliChlor shows good salt
    Time for an acid cleaning?
    35,000 Gal. - 40x20x8 - Plaster - SWG Pentair IC 60 - Barracuda G3 Vacuum - Hayward c1750 Cartridge Filter - Blue Torrent VS 1.5hp pump - Pool is 45 years old.
    "I'd build a deck over my pool if I didn't have a SWG"
    Jun 2011
    Long Beach, CA
    2,892
    You need to test the salt level. The best test for us homeowners is the Taylor K-1766 test, but a good batch of salt test strips will work. The problem with strips is that they do go bad and they are not as reliable as the Taylor test.
    I would remove the cell and inspect it for scaling. If it doesn't have scale don't clean it.
    Sep 2015
    Roanoke, TX
    4
    thanks. The acid cleaning referenced above would be for the cell as well (if scale is present), yes?
    Jun 2011
    Long Beach, CA
    2,892
    Only inside the cell if there is scaling.
