Results 1 to 7 of 7
Thread: Lowering water level
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    We got a TON of rain overnight!! I need to lower the water level fast. I just backwashed last week and don't really want to have to use more DE. Is there a way to use the Waste or Rinse on my multi port valve to drain some water without losing DE? Is gonna rain all morning...
    Denise-TFP Guide
    IG 13.6x30 gunite, Radiant Fusion Topaz, 3.6/5.6/4, 14100 gal, 2 skimmer, 4 Hayward LED lights (pool & spa), Hayward Echostar VSP, 2 future fire bowls, raised beam wall w/ scuppers,7x7 raised spa, DE Progrid70, SWG Hayward Goldline, OmniLogic, Hayward 400K BTU heater, stamped colored deck, Dolphin Discovery robotic cleaner, TF100 test kit, Newbie in Bixby Oklahoma
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: Lowering water level
    Waste will send pool water straight out, bypassing the filter.
    Jun 2014
    17,327
    Pull water to waste and it will bypass the filter and go straight to the lawn.
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Thank you both!!! I'm headed out now...water's almost to the deck!! Yikes!!
    Denise-TFP Guide
    Nursenini's Avatar
    Sep 2015
    Bixby, Ok
    2,122
    Danny, Pat and TFP for the win!!! Catastrophe avoided!! I SO appreciate you all!!
    Denise-TFP Guide
    Jun 2014
    17,327
    Awesome. Glad it worked out.
    Apr 2017
    Maine
    231
    Next time use a garden hose, push it fully into the water to fill the hose, plug one end and take it to a spot lower then your pool. Pull the opposite end up to where you want the water level to be and put something heavy on the hose to hold it at that height. Voila, good ole siphon stops when the water in the pool drops below the end you had in the high water.
