Thread: Pump running backwards now?
    Jun 2016
    Cincinnati, OH
    46
    So I got the filter and hoses back out from winter storage over the weekend. Hooked everything back up and started to fill. I dropped the pool water below the skimmer and return jet for the winter and plugged them both. I turn my pump on once i get to the right water level and now it's pushing water back through the skimmer instead of the return jet. Clueless as of why. When i shut everything down last year it was normal operation. I checked the valve on top the filter to release an air. All good there. Any clue what could possibly be going on?
    25k Gallon Freeform Gunite Pool, with Tagulus sand filter, Hayward 2HP pump, SWCG
    K-2006 test kit
    2 returns & water fountain on 3rd
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,316
    Re: Pump running backwards now?
    I know it's a silly question, but could the hoses be reversed in some way? Maybe a picture of the offending area might be in order...
    Bob - INTEX 12x24 owner (not setup yet), 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    2,192
    Do you have 3 phase power at your house?
    Did you put the plumbing back together right?
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    JoeSelf's Avatar
    Jun 2014
    Glassboro NJ
    422
    Hose from skimmer goes into the pump basket with the strainer (Clear Lid). Hose from filter goes back into pool.
    13700 gal, 32'x16'x54" AG oval, vinyl, Echo Canyon II, 8500 series, Narrow Yard, Safety Fence & Stair, Sta-Rite Crystal Flow T-210WF, 44 GPM, Hayward SP1580TL 1HP Pump, Aqua Luminator, Festiva wedding cake steps, March 2006, TFT-100, Speed-Stir, Sample Sizer. Avatar Credit: TJ Townsend
    Jun 2016
    Cincinnati, OH
    46
    Yea got it figured out. My goofy self had the 2 hoses mixed ha ha. But thanks for the help.
