Results 1 to 7 of 7
Thread: my number one advice: get a good filter!
    Jul 2016
    Gainesville, FL
    127
    I don't think this point is emphasized enough in the pool school. About a year ago, as a new pool owner I thought clear water is all about chemistry. I had all the kits, I was measuring chemicals once a day, SLAMing regularly, calculating values, keeping things within .5 ppm of targets. I spent a lot of time and money, and my pool was at best cloudy and at worst green. Until I replaced my small, old cartridge filter with a big DE filter. BAM! since then I just add some chlorine every once in a while, test water maybe once every 3 weeks, and water is clear as mountain springs!
    Inground 28000 gal Concrete, Hayward Progrid DE filter 6020, US motors 1.5hp pump (3450rpm) , Polaris 360
    600 gal hot tub, Spa Vita, Nature2+MPS
    domct203's Avatar
    Jun 2015
    CT
    3,890
    Re: my number one advice: get a good filter!
    Quote Originally Posted by archer636 View Post
    There should be no reason to "SLAM regularly".
    Clear water has many meanings. Clear of algae & bacteria/virus is most definitely a chemical issue.
    Clear of dirt and debris, all filter and brushing/vacuum habits.
    If you pool is turning green with algae, you are not maintaining proper sanitizer levels, and or not brushing poor/low circulation areas.
    You should be checking your water more frequently than once every 3 weeks, to just 'wing it' is somewhat reckless IMO.
    I do agree that it is important to properly size your pump/filter to your pool. I'm sorry to hear that yours was not sized properly from the start.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    May 2016
    West Bloomfield, MI
    756
    My filter has an easy life. I haven't tried this, but I'd be willing to bet that I could bypass my filter 90% of the time, and/or only use it capture visible debris and my water would still remain algae-free.
    I think it's much more about balancing chemicals and water circulation. My pool has very good circulation. If it didn't, I would up my brushing routine and pump runtime. I test and adjust chemicals everyday when the pool is warm and in-use. I can go 4-5 days when it's cool and not being used.
    I wonder if you old cartridge filter was restricting water flow and that played a part in your regular need to SLAM...
    Do you have a SWG? Is the pool completely shaded from the sun? I don't understand how you can go 3 weeks without testing and not have pretty significant swings in chemical levels.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    30,941
    The number one emphasis in swimming pool management is having ALL parts of the puzzle running correctly. Pumps, filters, chlorinating systems and an understanding of the chemistry all must be in synch for a pool to remain crystal clear and sanitary.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    No filter will cure a Green Pool, nor a cloudy one if it gets that way from lack of Chlorine. (A most frequent cause)
    If that works for you, fantastic, but it isn't a regimen we would suggest even to veteran pool owners. Rudimentary testing should be done much more often than every three weeks.
    Essential Links:
    Jul 2016
    Gainesville, FL
    127
    Quote Originally Posted by Patrick_B View Post
    not true. When I first got the DE my filthy green pool turned clear overnight. I have pictures
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Your pictures do not prove anything of the kind. No filter will CURE an Algae problem. Sure, it will filter out some suspended Algae, but until you kill every last cell, it will continue to return, and grow in the pool. There is no credible Bilogist on the planet that would agree with what you are saying, but that doesnt really matter either.
    What we know as absolute fact is that no filter for any pool will ever cause Algae to go away. It isn't up for debate, and there will be nothing in Pool School alluding to such nonsense. You are free to have all the success you want in your pool exactly as you wish. You can test every three weeks or never test the water, but it isn't advice we will recommend to anyone wanting a clean, safe, and sanitary pool.
    I have no illusions about convincing you, but you will not continue posting this bogus information. This discussion is closed.
    Essential Links:
