Results 1 to 7 of 7
Thread: 1st readings taking the cover off
    Hey guys. Just took the cover off to get ready for the summer
    Here are my initial readings. Not confident on the salt test. Have to redo
    Salt - 4600
    TC - 5
    TA - 70
    CYA - 40 -50
    Thoughts? Definitely need to raise thr CYA. Going to run it for today and re test tomorrow withoht adding anything. I have not run the pump yet
    Thanks
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: 1st readings taking the cover off
    Alright, looks good! What is the pH?
    Can you belive that is normally the first test i do and yesterday i forgot! Didnt realize it until late. Ill post back when i check it
    Thanks
    DFW, TX
    24,974
    LOL!!! You were too busy looking at that sparkly pool water!
    Ok. Just retested after 2 days running the pump during the day
    PH - 7.5
    FC - 3
    CC - 0
    TC - 3
    TA - 70
    CYA - 40
    May 2013
    South Jersey
    25
    Amazing that you had detectable chlorine levels through the winter
    25000 Gallon Pentair Intellichlor SWG Gunnite Pool with Heyward DE Filter/Pump
    Test Kit - Taylor K 2006
    I thought the same!
    My TC is now dont to 2 bjt CYA up to 60 as i added some powder to bring it up.
    I am assuming TC droooed because i do not have the SWG on yet because of the wayer temp
