Results 1 to 9 of 9
Thread: Question about mixing chemicals
    Apr 2017
    Hesperia, CA
    18
    I was just wondering, Can I add chemicals to raise TA while at the same time have chemicals in a sock, on my skimmer to raise CYA ?
    Thank you.... Mike
    18 X 38, 18K gal, IGP W/ Infinity Spa. EasyTouch 8 ch
    Pentair 1.5HP VS pump, Pentair Cartridge Filter
    Pentair 250K HD heater, Del Ozone Corona Discharge
    - Generator ( Eclipse 10 ).
    Pebble Tec Finish. Dolphin Triton Plus vacuum.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,917
    Re: Question about mixing chemicals
    Yes you may!
    The only two you really have to watch is chlorine and muratic acid.........they need about 15 mins in between them as they do not play together well. They should also be stored away from each other. Your muratic acid should be stored in a well vented area away from metal as the fumes can cause rust.
    Kim
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    Kim, your reply made me think of something. Muriatic acid is poured in front of a return. If you have a SWG making chlorine at the same time will this be bad news? Or is the chlorine concentration so low coming out of the return it doesn't matter? Ive been adding muriatic acid and not noticed a problem but not sure my SWG was producing chlorine at the same time.
    Maybe Im thinking too much
    7000k Viking fiberglass Bermuda, Sand filter w/glass, Pentair SuperfloVS, Pentair IC20 swg
    Raypak 106k, Dolphin s-200, Taylor k-2006c, Taylor k-1766, Speedstir, Little Giant cover pump.
    Jul 2012
    Tallahassee, FL
    33,917
    You know what??? That is a VERY good question!!!!
    It is more the fumes that mix and causes the problem so the SWG output of FC is not a problem!
    thanks for thinking about that!
    Kim
    Pyrodav's Avatar
    Dec 2016
    Chillicothe/ohio
    175
    That makes sense 's. Thanks for the clarification!
    Apr 2017
    Hesperia, CA
    18
    Thank you Kim... Very Much !!! I LOVE THIS SITE !!! $300 for set up my posterior !!!
    Jul 2012
    Tallahassee, FL
    33,917
    psssssssst did you know you can become a supporter? See the blue oval at the top of this page.
    It gets you a discount on the test kits, a discount at Swimming Pool Supplies - Pool Parts - INYOPools.com AND helps us keep the lights on!
    Kim
    Apr 2017
    Hesperia, CA
    18
    I will support... I promise...
    Jul 2012
    Tallahassee, FL
    33,917
    Let us know if there anything else we can help you with! Do what you can when you can. We will be here for you!
    Kim
