Results 1 to 9 of 9
Thread: New Pool. Advice on adding chemicals
    They opened my brand new pool a week ago. Water is crystal clear. SWG has just started getting warm enough to run. Test strip says high alkalinity and 0 free chlorine. Should I wait longer to let pool settle? Or should I do the backwash, add DE and then add stabilizer? Can I pour the DE in and then the stabilizer or should I give time in between? Thank you! I have never owned a pool, this is new to me.
    Bsmith
    NEW 16x32/inground vinyl
    DE/whisperflo pump/SWG
    (all pentair)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    10,158
    Re: New Pool. Advice on adding chemicals
    Pour in gallon and a half of regular 8.25% bleach to help that SWG get up to speed. Has salt been added and circulated? Has any CYA been added at all? Why would you need to backwash? Doesn't your filter already have DE in it? You're gonna need to keep some muriatic acid on hand to combat high PH and help lower your TA. Ditch those guess strips and get one of our recommended test kits pronto so we can speak the same language with accuracy. Spend some time in Pool School to get familiar with the basics. Welcome to the forum.
    Sfpat's Avatar
    Jul 2016
    tulsa
    113
    And as per the standard mantra on this site, get a good test kit to test the water yourself.
    40 year old pool, 35k gal w/spa, gunite replastered July 2016, Hayward Sand filter, Hayward 1.5 hp single speed pump, TF-100, Kreepy Krauly suction side cleaner Dolphin M400
    Thank you for replying. They added everything when they opened my pool. However, it was a little too full and they said I could empty some out at some point (why they didn't put the water at a correct level before adding everything, I don't know) I didn't want to waste everything they just put in so the pool is still a little full (just above top of skimmer). My SWG has all green lights so I think it is doing it's job. The reason I'm thinking to backwash was to 1. Empty some water and 2, it says to backwash before adding stabilizer so I thought I had to do that. I definitely need to get my own testing kit it sounds like!
    Bsmith
    (all pentair)
    Apr 2010
    East Texas
    10,158
    Skimming action is most effective with water level at mid point of skimmer face. Does your filter have an option of "Waste" on it?
    It does have a waste option. If I use that setting to empty some water, it does not backwash the filter and I do not need to add DE, correct? As far as the bleach, they never even mentioned having to add bleach to the water. Would I pour that directly into the pool or in skimmer?
    Bsmith
    (all pentair)
    40,879
    Welcome!
    We do not recommend pouring the CYA into the skimmer, or really adding anything to the skimmer. Check out ABCs article in pool school.
    You are correct that waste just bypasses the filter completely.
    Apr 2010
    East Texas
    10,158
    SLOWLY pour a pencil sized stream of bleach directly in front of a running return jet to your pool. Let it circulate for half an hour. Will keep your SWG from having to work over time to get up to 4-6 ppm of chlorine initially.
    Great, thank you so much.. I have been reading up all day on this site, very helpful.
    Bsmith
    (all pentair)
