Results 1 to 9 of 9
Thread: From green swamp water to an aqua color, but wont clear.
    Jan 2013
    Coral Springs, FL
    20
    The past 2 months, Ive been working aggressively to clean my swamp water. It now looks better as an aqua color but still wont clear. I also bought a new cartridge for the filter and clean it about every three to four days; especially when I see the pressure (on the gauge) go up. And when I clean it, theres a whitish-grayish slugged or slim thats being hosed out. Ive been keeping the chlorine level high; my numbers from the latest test are below.
    FC = 110 ppm
    CC = 1.6 ppm
    Ph = 7.2
    TA = 100
    CYA = 30 to 35
    Gallons = 10,000, In Ground plaster
    Filter = Hayward 17502
    Pump Flotech 1.5 HP, one speed (GPM unknown)
    Build date unknown, house built early 70s, so sometime thereafter
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    33,884
    Re: From green swamp water to an aqua color, but wont clear.
    I REALLY hoping the 110 should be 11.0
    How often are you testing and redosing the FC?
    Are you running the fitler 24/7?
    Call your CYA 40 as we round up.
    Please take and share a pic so we can see what you are dealing with.
    Kim
    Jan 2013
    Coral Springs, FL
    20
    Yes; I do mean 11.0. I test the water about every 3 days. Over the past month, the pump has run 24/7 but I have turned it off overnight a few times. The upcoming electric bill will sting. Heres a pic.
    30,941
    Test your pool not less than every 12 hours.....you are not SLAMming.
    Bring your FC to 16 ppm and KEEP IT THERE until your pool is pristine.
    Shutting the pump off only lengthens the time to clear and costs you MORE pump run time.....not less.
    That pump is wa-a-a-y to big for a 10k pool get a one HP 2 speed or a VS....the electricity savings will pay for your purchase.
    clambert1273's Avatar
    Jun 2013
    Cerritos, CA
    577
    If it is cloudy (and I have had this issue), the to me that suggests a slam isn't fully completed and algae is there somewhere. FC should be maintained around 16 with CYA of 40 so you might try that a few days and brushing down real good a couple times per day.
    I am lucky enough to work from home so when I know there is a problem I can test/dose every hour or 2 so it is a short cycle for me
    Christina
    ~14,000gal 14x30 IG vinyl, Hayward DE4820 filter (everything else is too old to read lol), TF100 Test Kit, TFPC method
    POOL SCHOOL, ABC'S of WATER CHEMISTRY, POOL MATH, SUPPORT TFP!!, TEST KIT!
    May 2016
    West Bloomfield, MI
    756
    Jimmi, you can drop the pH testing from your routine while you keep FC at SLAM levels, but that floater suggests that you're using pucks to chlorinate. Is that the case?
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    Jan 2013
    Coral Springs, FL
    20
    I thought bigger was better (-:
    This is the existing pump when I bought this house. I’ve heard of 2-speed pumps but not familiar with them. I’ll look in to it if they are energy efficient. How well would they work with my filter?
    Jan 2013
    Coral Springs, FL
    20
    Quote Originally Posted by Rollercoastr View Post
    I stuff as many pucks as possible in the floater. Is this contraindicated when doing the SLAM procedure?
    Ive been using the granular chlorine in the pic and went through half of it in two months. Recently I used liquid chlorine and although still cloudy, now I can see 6-foot deep end. I think something is going right.
    Jul 2012
    Tallahassee, FL
    33,884
    Every puck you use and scoop of powder you put in is making your CYA go up The higher your CYA goes up the more FC you will need. PLEASE go take the pucks out of the pool. You might want to retest the CYA in the morning to see where it is at now.
    Get and use liquid chlorine/bleach only.
    Kim
