Thread: Searching for filters
    Apr 2017
    Conyers, Ga.
    4
    I have a Jandy LXI pool heater and the high limits have gone bad. I read on some other threads about checking the bypass and cleaning the filters. Can anyone advise me as to where these items would be found?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Searching for filters
    Welcome to TFP Jerry,
    If you can post a couple of pictures of your pad, we can look at it and help you figure this out more easily.
    Essential Links:
    22,702
    If you have a bypass, it'll be a piece of pipe with a valve between the inlet and outlet of the heater, and the filter they're talking about is the main pool filter.
    If the temperature high limits are bad, the only recourse is to replace them.
    How did you determine that the high limits are bad?
    Apr 2017
    Conyers, Ga.
    4
    Actually only one is bad (open on an ohm meter) but I figured I should probably replace both and I also feel like something else had to have caused it. I service furnaces pretty often and on them bad high limits/ flame roll outs/ etc are usually a symptom of another problem.
    Dec 2014
    Houston, Texas
    134
    As to your original question of checking the bypass and cleaning the filters I would have to assume they're talking about the pool filter not a filter in the heater, never heard of one except on high dollar efficient ones. As to the bypass, the Lxi has a bypass in the in/out header. Threads in and can be unscrewed and checked for integrity, please google a video to know what your looking for as it has an adjustment screw that you don't want to move w/o the proper temp rise kit. If you have a limit out and the heater is off it needs replacement. They do wear out and if the Lxi is anything like the LT/LX its totally normal. In the LT/LX the limits sit in a well against a brass screw and were prone to scale build-up by electrolysis or reaction to different metals touching with water involved.
    GL!
    Apr 2017
    Conyers, Ga.
    4
    Thank you Joel Fitz!
