Results 1 to 18 of 18
Thread: Sta-Rite Sr400 Heater Wont stay fired up.
    Apr 2017
    Las Vegas NV
    8
    First Time here.. Thanks in Advance..
    I have a Sta-rite SR400 pool heater.. its a little rough on the outside due to the harsh sun here in LV, but once I removed the cover, it doesn't look all that bad. There were some leaves and stuff under the cover, but I vacuumed that all out. (no varmints )
    As Of right now I turn it on, it struggles to lite, eventually gets lit then shuts down after a few seconds of running (never runs more then 20 seconds) The blower continues, it starts the process over. (sometimes it never actually gets lit)
    Wondering where I should start? I have looked over the forum, but all posts seem to be older.
    Thanks
    Greg
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,999
    Re: Sta-Rite Sr400 Heater Wont stay fired up.
    Hey Greg,
    Welcome to TFP.
    Sorry I won't offer much, but maybe one of our experts on heaters will pick this up today. PS0303 is a heater guy and he will know what to suggest. Wish you luck and hope you enjoy the forum.
    Essential Links:
    Any error codes or lights on back of control board?
    Support the site
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    Since it's cycling it could be several issues. Could be a blower motor issue or even water in the canister.
    Paul
    Gastek Pool & Gas Services If you would like to provide a review of the help I provided, please use the following link to leave a review. Gastek Google review,
    Check out some videos on my YouTube channel - Gastekservices on YouTube
    Apr 2017
    Las Vegas NV
    8
    Ok thanks for the Start..
    I have read about both the LEDs and Codes..
    Can someone give me a down and dirty how to investigate this?
    Where can I find the LEDs? I have not opened the grey box inside of the shell yet..
    Thanks again for everything
    Apr 2017
    Las Vegas NV
    8
    Also..
    The blower motor seems to sound fine? should i be listening for something else?
    Thanks again
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    572
    I would start by cleaning out the combustion chamber.
    With dirt and or debris in there is will not start easily and will time out.
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    Quote Originally Posted by blakeusa View Post
    You can't do this on these units. The burners are in a sealed canister. It takes lots of work and if you don't seal the canister up correctly when you're done, you have possibly created a fire hazard.
    Paul
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    Quote Originally Posted by gregpfeifer View Post
    Also..
    Thanks again
    Well unless you work on them all the time you will not notice a sound change or how strong it is blowing.
    For starters, open the cover by removing the four screws that hols the two halves together. Once you have done this, the top comes off when you remove two pins that hold it in place. Now you can flip the top over and there are LEDs on the back hat IF it shows you an error code on the display, you can see what it is referencing. Seeing your system is NOT giving you an error code but cycling, I do not think looking at the LEDs will help you at all.
    Cycling can be several things as I stated earlier. It could also possibly be a bad ignitor as well. How are your troubleshooting skills?
    Paul
    Apr 2017
    Las Vegas NV
    8
    I am pretty handy.. I am also a good listener..
    I will start with removing the covers and investigating error codes first. When would it give me this error code?
    I am starting from scratch.. I am assuming you are saying it will not show an error code while its cycling ?
    Thanks for your patience.
    Greg
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    It will not show an error code while cycling. This is why I say looking at the back of the board won't tell you much.
    So does it light and then go out and then light and go out, etc? If you can video it and post that can help also.
    Paul
    Apr 2017
    Las Vegas NV
    8
    So You can see what I am working with... I have to read the display at night. ( The Sun here in LV is HARSH)
    When its Cycling.. The three lights to the left lite individually across..
    I Will start looking into the ignitor.
    I will make video tonight when we are able to see the display a little better..
    Thanks for all this help..
    Greg
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    You definitely need to replace the keypad membrane and probably the board underneath. Once that keypad is shot like yours, you have left the board exposed to the elements. You will get all sorts of issues with the keypad like that. Start with replacing the keypad membrane and then lets see what happens.
    Glad I asked for a picture because I could have you chasing your tail when it just might be only the keypad. Visual inspection is a big part of diagnosing issues.
    When you get the new keypad, peel the old one off and stick the new one on. Pretty easy but make sure you put the new one on straight.
    Paul
    Apr 2017
    Las Vegas NV
    8
    Ok thanks again..
    Here is my only problem.. I don't want to invest to much money into this if there is a major problem..
    Is replacing the membrane fairly cheap?
    Where is the best place to get one?
    Apr 2017
    Las Vegas NV
    8
    Here are some videos to help this along..
    SR400 Pool Heater not firing - YouTube
    Thanks much
    Greg
    Here is another one..
    sr400 Control Panel - YouTube
    Thanks again
    Apr 2017
    Las Vegas NV
    8
    I bet this is the problem..
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,609
    Greg, how old is the heater?
    Dolphin E10 Cleaning Robot.
    ps0303's Avatar
    Jul 2011
    FL
    3,925
    Watched your videos. OK so here is what I would say neds to be done. I see you removed the thermo regulator which is shot. You also need to check the bypass valve which you can feel up inside the top area where the regulator goes. It should feel like a round button of sorts. If you don't feel it, then its gone and need sot be replaced. You should also remove the bottom bolt on the header, where the eater flows in and out, and if when you remove it, water comes out, your are done. The heat exchanger has a hole(s) in it and not worth repairing.
    I would have to tell you that you are probably better off replacing the unit or hiring a repair company to come out and chase down all of the issues you have.
    Paul
