In my sig is my current intex build and setup (2100 gph sand pump that came with the 18x52 6900 gallon pool)..
I'd like to get our pool into the mid 70s for mid april NE weather, rather than the current 53, so on warmer 70+ days it can be used.. same deal for october.. so i looked into options.. i saw the regular "Hose" game solar device and I dont think it had enough oomph to do this job.. then i spotted this smart pool S6101P
So.. for those that have used it.. i had a few questions.
Seems unclear from the amazon link whether i have to spend a ton more to make it work (beyond pvc piping and fasteners for the roof).
My situation (can see some pics in my build link in my sig).. is that i have a garage directly behind my deck, maybe 25 feet from the pool give or take.. i have a salt water system..
Its my understanding that this solar system would tap in, in between the sand pump and salt water system off a T with a regulator going to the solar panels?
If so, i guess i would make it go 25 feet to the garage, then up the 8 feet or so and across to the side of my garage where i would lay the panels on the pitched roof, which gets plenty of sunlight.. then back to the pool.. i think from what i'm seeing it goes into the pools return (another T).. but i also have an unused outlet i could turn into a hot water return (i think no issue with that?).
Wondering how you keep the water from getting too hot.. do you just put a valve on the line that goes to the roof?
Has anyone used this system and can comment on if it performs as well as many say (IE: mid 50s in april, week later might be 76 in the water)..
Will my 2100gph pump manage to push the water 30 feet up and around and back.
Or i might need to spend $250 on a 4500 gph pump i was considering anyway, if too weak?
Or perhaps theres a simpler solution to all this?
Thanks in advance for any tips on this one everyone
