Results 1 to 7 of 7
Thread: CYA level of about 110, should I drain?
    flyboy320's Avatar
    Jul 2009
    Burlington, Ontario, Canada
    216
    I've had my pool for about 7 years and have done all the maintenance on it myself. I noticed every spring when I opened, I had to add stabilizer to bring it up to about 30 (using the liquidator and 12% chlorine) and I assumed this was due to the pool water being diluted in the summer with rain, thunderstorms, and me partly draining for the winter months. This year I bought a new bottle of the CYA tester (Taylor kit), and it showed my level at about 110 I'm guessing the old test bottle was bad, but at any rate, my pool is sitting at that level and I'm wondering is there any detriment with having the CYA at that level? I guess I'll have to have a chlorine level of about 10, would you notice this higher level when swimming? If I drain, is there a possibility the vinyl liner could be damaged, come away from the pool wall (it's about 7 years old)?
    10K gal IG, vinyl, 1 HP Jandy Stealth pump, Jandy CS cartridge filter, Delta UV system, Hasa Liquidator
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    9,297
    Re: CYA level of about 110, should I drain?
    FB,
    You can drain in stages... Drain about 25% and refill, retest CYA, and decide if you need to drain another 25%.
    Only draining 25% at a time, should prevent any liner issues..
    Unless you are running a SWCG pool, your CYA should be 60 or less..
    flyboy320's Avatar
    Jul 2009
    216
    Good plan, I'll retest next week, and if the level is still around 100, I'll do as you suggest and drain in stages.
    Does the water temperature or PH affect the CYA test (water is still only around 55f and the PH was a bit low when I opened around 7.1 but has since been brought back to 7.5)
    Jul 2014
    Bedford, TX
    9,297
    FB,
    pH no, temperature maybe.
    Just read something today which suggests that temperature does not effect the CYA test. But I always let the water warm up to room temp before doing the CYA test outside.
    May just be an old myth about temperature, but if it has no effect, then warming it up to room temp will not have a negative effect either..
    Sfpat's Avatar
    Jul 2016
    tulsa
    113
    first question to ask is How did the CYA get so high? Have you been using tablets, shock? CYA just doesn't appear on it's own.
    40 year old pool, 35k gal w/spa, gunite replastered July 2016, Hayward Sand filter, Hayward 1.5 hp single speed pump, TF-100, Kreepy Krauly suction side cleaner Dolphin M400
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,900
    Quote Originally Posted by flyboy320 View Post
    Sometimes I'm an outlier on this issue. IF there is no reason to drain other than lowering CYA, meaning no algae or other issues then yes, you can wait.
    When I bought my current house the best I can figure is that the CYA was in the 250 range. I kept my FC in line for that level of CYA and took it slow over a couple of years and now I have it at my 50 that I want. I did rig up a hose offf of one of the gutter downspouts so that every time it rains "extra" water goes into the pool.
    Support the site
    flyboy320's Avatar
    Jul 2009
    216
    No issues other than the high CYA level. I think I'll wait and see how it goes this spring and if I can't keep the algae under control I'll try draining some water. It was fine all last summer even though I don't know how high the CYA level was, so I think I should be fine this summer.
