Results 1 to 11 of 11
Thread: Curious when testing FC
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    257
    Its states to get a precise measurement of chlorine to fill up to the 25 mark, then times by 0.2.....Now reading in the How to section, it says you rarely have to do that, and just use the 10 line mark, and times by 0.5 to save on regeant. Now when I do this at the 25 marker, it reads fc 15.8, and when I do it at the 10 marker, its 12.5...Isnt that a big difference? Because when testing, and you want to be in the normal range, wont that give you a false reading by doing the 10 marker line? And poss get below level and risk of algae bloom.....I bought a big bottle of the DPD powder, so im not worried, but just curious how effective to always use the 10 marker rather than the 25..
    24x16 doughboy Summerville..22" Waterway "sand" 1.5 HP 2sp motor..Misty Falls liner, and wedding cake stairs..
    40,883
    Re: Curious when testing FC
    That is a big difference and must be testing error somehow.
    Did you really count 79 drops with the 25ml sample and 25 with the 10ml sample.
    If you take too long, you could have ended up using more drops with the 25ml sample since it will always turn back to pink.
    mepcards's Avatar
    Sep 2015
    mesquite,tx
    257
    Correct numbers...I usually just use the 10 marker to save on powder, but wanted to get a precise reading for im letting my levels of FC come down to normal...Had a little algae I was battling....So today I put one scoop in and filled to the 25 mark..Took 79 drops to get water clear....When I rinsed out thoroughly, I tested again at the 10 marker to just see how far off it really is...Put one scoop in, then filled to the 10...after 25 drops, the water clear....and if I do the math correctly, 79 x 0.2 is 15.8..........25 x 0.5 is 12.5....did not let it sit....worked normal speed
    40,883
    The larger water sample requires more powder than the smaller sample. But if it turned a deep pink, should be fine. How are you stirring?
    Apr 2016
    canon ga
    3
    My taylor kit dosent say use less powder with the 10ml only to change your calculation number, says add 2 scoops
    Mar 2016
    Gilbert AZ
    45
    I believe we have the same kit, I used to do the full test but have since switched, the problem could be that you are taking too long swirling the water after each drop and thus the color starts shifting back towards pink, my suggestion is to buy and use the little magnetic pill mixer for more consistent results.
    11,507 Gallons | In Ground Pebble Tec | QC XHP In Ground Cleaning System | System 3 MM Sta-Rite Filter | Pentair VS-T 3050 Pump | Pentair Ultra Temp 120 H/C | QuickPure 3 Ozone | K2006 Test Kit
    Captain 776's Avatar
    May 2016
    Thailand
    163
    Exactly what I was going to say. I use 10 Ml and use 2 scoops but I am careful not to dip the dipper below the spoon part of it and get 2 equal level scoops. More important to do it the same way each time.
    8M x 4M X 2M no slope IG CONCRETE w/ceramic glass tile
    17,000 Gal EMAUX SWG JAZZI FILTER W/1-3 mm glass media, Jazzi Multi-port valve with
    T-750 filter w/ glass media
    1 main drain sump -3 returns - 1 skimmer
    Kokido digital salinity tester, Kokida drops for CL Hanna digital PH meter, Taylor K-2006
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,137
    Are you rinsing with pool water or tap water? I normally use pool water between tests, but once I forgot and used tap water and didn't dry before doing a new test. The lower chlorine tap water droplets left in the vial were enough to thrown off the next sample reading and make it read lower than actual.
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    domct203's Avatar
    Jun 2015
    CT
    3,908
    Quote Originally Posted by mepcards View Post
    The amount of DPD powder is not critical, use enough to get a good vibrant pink color, but don't be wasteful about it. I use a heaping spoon in the 10ml sample.
    The problem with the 25ml sample is the number of drops of reagent needed to get the result (10ppm at 0.2ppm per drop is 50 drops vs 20 drops at 0.5ppm each). I'm somewhat impatient and will tend to rush through the drops if I have a lot of them to do. I have to force myself to slow down and drop at a rate of about 1-drop per second. If you rush the drops, they will be undersized and skew your results to be higher than they actually are.
    Collect a sample from the pool to run the 10ml test a couple of times in a row, they should repeat within reason (the higher your FC, the greater the chance of error). I found my testing using the 10ml sample (with speed stir) to always be within 1-drop/0.5ppm. That's good enough for me.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    Aug 2016
    Riverside, CA
    378
    If there's a slight bit of the DPD powder in the test cylinder there's enough. Once it reaches saturation it falls out of solution or just won't go into solution.
    Feb 2015
    Chandler AZ
    1,061
    I took the liberty to bold the text that stood out to me....
    You should fill the vial with pool water to the desired mark first and add the scoop of powder after to get a more accurate reading.
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
