Thread: where get deep socket couplers and elbows
    Jun 2014
    new york
    26
    hello!!
    rebuilding my pool and ... was reading before that all pvc pipes should be connected by longer couplers and 90deg, 45 deg elbows. where can i get them ... home depot seems only has drain/waste pipes stuff not for pools ..
    Mod Squad pooldv's Avatar
    DFW, TX
    24,974
    Re: where get deep socket couplers and elbows
    Lowes has DWV pipe fittings in a section and sch 40 pipe fittings in a separate, smaller section. What you want are sch 40 fittings.
    40,883
    Agreed, you just should use schedule 40, which is typically not the dwv.
    I am sure home depot has the correct fittings
    Jun 2014
    new york
    26
    thank you ,i got it schedule 40,
    but pvc pipes from home depot regular ones 2" are ok??
    i guess i have some left regular clear glue for pvc pipes and primer is that ok or should i get some special glue for pressured pool water flow
    40,883
    Regular schedule 40 PVC is correct. If the primer and solvent is for PVC and is not jelly-ed , it should be fine too.
    May 2009
    Youngsville NC
    395
    Typical pipe sizes are 1.5 to 2, maybe 3 inches. Older pools usually have 1.5 inch, newer one seem to be built with 2 inch or larger. Just get the same size fittings for the pipes you have. Yes Schedule 40 (maybe schedule 80 going in / out of a heater). I like using the purple primer myself - easy to tell where it has been applied - and I use almost any kind of approved PVC solvent. Do give it time to set (30 minutes or so) before pumping water through it if you can.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
