Thread: How to fix a leak on pvc without taking it off
    Jul 2013
    Long Island, NY
    557
    I used a pvc adapter to screw into the plastic intex piece. As you can see there is a drip. I guess I tightened it all hard I can't untighten. I used oatey great white (no teflon tape under it). Is there something I can do to seal the drip.
    Gallons: 5000 Gallons
    Pool: 15' Saltwater 5000
    Filter: Pentair 1 HP Optiflow Pump w/ Clean & Clear 75Sq Ft Cartridge Filter
    SWG: Intex CS8110
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    507
    Re: How to fix a leak on pvc without taking it off
    Depending on the leak should be able to put a piece of rubber over the leak and hose clamp it on both ends.
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
    Jul 2013
    Long Island, NY
    557
    I should add I don't care if the solution will permanently affix it to the intex.
    Actually that idea you just gave is making me wonder if flex seal will work???????
    SWG: Intex CS8110
